jonesg wrote: ↑09 Sep 2024, 02:50 wheel bearings drone or hum.
friction noise, more likely to be the dust shield or brake shoe/pad clearance but you wouldn't feel it in the driver seat.
pain in the neck but you could reinstall the prop shaft to eliminate. or disconnect it to eliminate anything in the rear end.
or turn the radio up and wait til it becomes more obvious.
Vibration under seat at most speed
arrrxivvv
- Year and Model: 2004 XC70
- Has thanked: 16 times
- Been thanked: 10 times
Re: Vibration under seat at most speed
Thanks, perhaps I'll wait a while since the vibration is not yet too bad.
04 XC70 206k
- Has thanked: 1843 times
- Been thanked: 1710 times
If they rotated the tires and the shake is still through the seat, it is not the wheels or tires if you are not feeling it through the steering wheel too.
The parking brakes could still be the issue. A stuck parking brake cable, or a sticking rear caliper will also cause these issues. After you have driven the car, CAREFULLY!! touch the rear wheels near the center and feel if either hub is hot. Careful it can get really hot!!
arrrxivvv
It's interesting to know about potential parking brakes issue. Just finished a drive, the rotors were warm but I was able to briefly touch them without burning myself.
scot850 wrote: ↑09 Sep 2024, 18:40 If they rotated the tires and the shake is still through the seat, it is not the wheels or tires if you are not feeling it through the steering wheel too.
04 XC70 206k
