1998 Volvo S70-T5 TENSIONER ALMOST DESTROYED ENGINE
800artfreed
Year and Model: 98 S70T5; 99 S70GLt
Been thanked: 26 times
Post by 800artfreed »
Recently I put my 1998 S70 in the carport to do some maintenance. When I started the engine to warm up the transmission fluid I heard a strange rattle coming from the timing belt (TB) area. I shut down and removed the TB cover. Starting up again the noise was louder. I shut down and began a careful inspection. The result was horrifying. A plastic ring was at the bottom of the TB cover area inside the path of the belt. This was being picked up by the belt and bounced against the TB cover. Further inspection found a flat piece of plastic at the bottom of the TB area below the crankshaft pulley. This came from the fixed TB cover and the location can be seen in photo #3. The TB was loose coming off the intake cam pulley and the idler pulley! Lastly and most horrifying was the condition of the tensioner. The indicator finger that is supposed to be centered between the reference "pointers" was now actually below the timing belt. The reference pointer was all the way counter clockwise in the 10-11 o'clock position. Not at the top of the tensioner.
I removed the plugs and spun the engine by hand. Fortunately the timing marks all line up. The engine had not been destroyed.
I tried to adjust the tensioner but the first restart put it back the way I found it. THE TENSIONER HAS FAILED! This part was installed when I bought the car with 159K miles on it. The car now has 209K miles. It is the standard part in the FCPEuro TB kit they sell (Volvo Timing Belt Tensioner - INA 30638277). I ordered a new tensioner and will submit the old part under their Lifetime Guarantee. I still have to pre-purchase a new part and pay postage return postage.
While I am grateful the problem was discovered before serious (destroyed) engine damage occurred, I was not looking forward to having to change out the tensioner in the midst of fixing an oil leak, flushing/bleeding brakes, adjusting parking brake system, etc on my 26 year old car.
Plastic parts found in the TB area. Ring from the tensioner and flat plastic from the fixed TB cover.  See 3rd photo with diagonal edge at "9 o'clock" position
Missing indicator and wrong position of reference guide.  Other plastic ring on the tensioner
Look carefully at the tensioner to see the ring and the location of the broken flat piece of plastic shown in the first photo
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Probably should have bought a lottery ticket that day......
1999 V70 GLT
Has thanked: 2199 times
Been thanked: 1851 times
Strange failure. I know they fail, but the plastic from the cover being broken off is to me the stranger part. It looks like the bolt hole internal plastic.
You might want to just check the engine mount under the crank pulley to make sure it is not separated and the engine moving around.
Has thanked: 1609 times
Been thanked: 4065 times
I lost an InA tensioner on Elizabeth the 99 V70 and was not so lucky. I got to repeat a valve job and replace all the valves. Luckily. All the parts were FreeCP
