I have 1996 850, no turbo. This happy little thing lets me use the AC when it feels like it!
When I first turn it on, it works fine. If I stop n Go into a store, when I come back and get into car, no workie.
If I am riding on highway, as long as spped is same and dont stop, workie. If I stop, no workie. If RPM goes high to overtake, Stop Workie.
Recently too, the blower quit, fuse okay, compressor works and as I move the ac blows in cold aire whilst in motion. but if any of the above happen, it go bye bye. This has baffled me for quite a few years now.
Have done a bypass on pressure sensors (two) and nothing. Charge is fine too.
Thanks in advance for any help on the subject!
Art
Weird AC Problem
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
It sounds like the compressor clutch gap has gotten too large. It can be shimmed without replacing the compressor. I believe the repair is in the repair database section.
artbar92706
- Year and Model:
would that prevent the clutch from engaging? I cant even hear a click or anything like when you normally turn it on & off
MadeInJapan
Yes it does...you don't hear the click because it doesn't engage...this is all said assuming that you have the right amount of gas in the system.
- Year and Model: Many Volvos
- Been thanked: 76 times
+1 on the clutch gap. Here are some links to good threads that discuss the subject.
http://volvospeed.com/vs_forum/Ac-Therm ... 76833.html
Be sure to see N8-50's writeup.
Here is a link to the ghetto fix:
http://volvospeed.com/vs_forum/index.ph ... opic=80181
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
Most cars have a cutout switch to turn off the AC at full throttle to give you maximum passing power.artbar92706 wrote:If RPM goes high to overtake, Stop Workie.
MadeInJapan
True, but for the A/C to then not come back on typically points to the compressor clutch. Many have had the same issue here and have fixed it from looking at Lee's provided links.
Hi All,
I had the same problem with my BMW.(sorry) It turns out the condenser fan seized. I would get great cooling at highway speed but nil in around town driving. Sometimes the electric condenser fan gets hard to turn due to bearing failure or rubbing on another component. Under or overcharged systems will have somewhat the same symtoms.
Quote: "If there is a 50-50 chance that something can go wrong, then 9 times out of ten it will. "
Paul Harvey
Paul Harvey
Doug <///><
1999 Volvo V70 LT AWD X/C 143k back from the dead.
1995 Jeep Rangler Rio Grande 243k
1994 BMW 325i Sedan 226k
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
My radiator fan relay (I think that is what it is called) was going bad and I had the same symptoms. Make yourself a little alligator clip jump cable and next time you get into the car and the compressor won't work, jump the fan relay and make the radiator fan turn on. The compressor should turn on then if the relay is going bad. If it doesn't then it's something else.
1995 850 GLT Wagon w/ 200,000 miles
- 1267 Views
Last post by james02s40
- 1241 Views
Last post by Window_Licker
- 2638 Views
Last post by Antong2
- 490 Views
Last post by Grba
- 1099 Views
Last post by difflock54
