Brake booster release switch location needed 2007 3.2
vmaxmike
Year and Model: 2007 XC90 3.2 190k
Post by vmaxmike »
Hi,
A traction control warning message is displayed along with the dash light and scan tool shows error code C111802 Brake Booster Release Switch is at fault. Where exactly is this part located please so I can replace it? Is it on the booster itself? Thanks
Capndirk
Year and Model: 2009 XC90
Has thanked: 14 times
Been thanked: 14 times
Post by Capndirk »
https://www.dtcdecode.com/Volvo/BCM-C111801
Found some info here. Maybe get you close in parts search?
vmaxmike
Post by vmaxmike »
later realized I could just click on "service manual" at bottom of screen to get more info, and it does in fact point to the pedal pressure sensor which is the cylinder shaped thing that sticks out of the booster so I'll try replacing that.
vmaxmike
Post by vmaxmike »
That DTC decode website is a great resource though. Thanks!
mirotvoretc
Year and Model: 2010 Volvo XC90
Post by mirotvoretc »
Hi buddy! How did you resolve Brake Booster switch ? I got same problem - C111802..(
Thanks!
Best regards
Has thanked: 311 times
Been thanked: 817 times
Procedure is likely slightly different on your 2010 car but:
