Height 30mm and new springs. Must approach 1.5 dm between deck and upper fender edge. Sits level matic. Also moved the lower damper bracket up and put a spacer there, without knowing for sure how the level mat dampers work, I thought it should be best to have them in roughly the same zero position.
Tried googeling for a new rear stabilizer but almost just find original and i find them expensive.Does anyone know if i can replace the upper mounts with something else so i dont have to change the hole setup?
Translated by google
