Are S60 fuel tanks steel? - 02 S60 2.4T
Has thanked: 2210 times
Been thanked: 1852 times
I posted naturally in the wrong thread (P80) for this question. Are P2 S60 FWD fuel tanks steel or plastic (like a P80). I know CA had requirements for steel tanks, but I can't find any info on this. Trying to help find a tank for a friend which is hard as all the PnP yards puncture the tanks here, which is very helpful.............
Neil
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
This was discussed a few days ago in topic viewtopic.php?t=105238
04s60 2.4
04xc70 2.5t
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
scot850 wrote: 17 Sep 2024, 10:26 I posted naturally in the wrong thread (P80) for this question. Are P2 S60 FWD fuel tanks steel or plastic (like a P80). I know CA had requirements for steel tanks, but I can't find any info on this. Trying to help find a tank for a friend which is hard as all the PnP yards puncture the tanks here, which is very helpful.............
Neil
you can verify with a magnet.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
jonesg wrote: 18 Sep 2024, 01:44
Neil
If only magnets were easily available...
Oh wait! They are :D and they come styled to be the envy of your car club! https://www.matthewsvolvosite.com/vikin ... se-badges/
Also -> Amazon link
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
Post by Faust »
If I understand it correctly, the Calif and Mass cars with steel tanks are engine coded in the VIN as B64. This may have been a running change for all Volvos. If the car is accessible above ground feel for a fuel filter by the tank, if you don't find one ahead of the right rear wheel it is a steel tank car.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
My friend went to the junkyard today and pulled a tank to try to help figure out why he is getting a leak only when lifting the car on the drivers' side. Otherwise it does not leak. I've asked him if he is getting any emissions codes as that is weird. I'm wondering if it could be the roll-over valve. I'll have to take a look to see what is on that side that could cause it.
The tank my friend pulled he concluded was a metal tank but coated in a plastic type material. Not sure what year he pulled. Most P2's I've seen have the fuel filter under the RHS rear fender area forward of the axle.
Faust
Post by Faust »
Here is a video on replacing fuel pump in steel tank car:
Please note that every so often he decides to go off camera, those are points that are really going to cause trouble and you would really appreciate video guidance.
2004 V70
