I can change gears without the key being in the ignition, 2007 XC70
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
Check the shifter lock cable on the left side of the console, you'll need to take the drivers side trim off the console side. there's a yellow connector block on the end of the cable that attaches it to the shifter that may be broken. Excluding that, the column lock may have something broken where this cable goes into it. Normally the key has to go to position 2 in the column lock to move the shifter. You'll have to remove the steering column to access the cable and column lock which is just a few torx T-25's and a flathead screwdriver to see where it attaches on the shifter. It should be pretty easy to find the problem with this trim off.
2003 XC 70 (sold)
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Might be the shifter knob button as well. It can break and get jammed causing the rod to always be engaged. I would remove the shifter knob and look inside and check the movement. It's very easy to do just don't accidentally punch yourself square in the mouth like I did when I was removing mine.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.AylmerQc wrote: 25 Sep 2024, 07:32 Is there something broken or that needs adjusting to remedy this?
I'm almost positive the second video in the link will provide enough info on tearing into it and finding the problem. For me the shifter broke and was having a very difficult time going into and out of gears.
(EDIT: Should Be The Same Assembly According To Volvo Website IIRC)
Console Removal
viewtopic.php?p=644911&hilit=2012+XC90#p644911
Yellow Connector Block per Blacklab467
viewtopic.php?p=644386&hilit=2012+XC90#p644386
Don't Try This At Home
viewtopic.php?p=646002&hilit=2012+XC90#p646002
- Has thanked: 987 times
- Been thanked: 1075 times
On my 2001 V70, the shifter button is permanently depressed by a botched button replacement. It allows shifting through all gears without pushing the shift lock button.br0dy519 wrote: 25 Sep 2024, 10:56 Might be the shifter knob button as well. It can break and get jammed causing the rod to always be engaged. I would remove the shifter knob and look inside and check the movement. It's very easy to do just don't accidentally punch yourself square in the mouth like I did when I was removing mine.
It does not allow shifting in OFF or Position 1.
- MoVolvos
.volvolugnut wrote: 25 Sep 2024, 15:22On my 2001 V70, the shifter button is permanently depressed by a botched button replacement. It allows shifting through all gears without pushing the shift lock button.br0dy519 wrote: 25 Sep 2024, 10:56 Might be the shifter knob button as well. It can break and get jammed causing the rod to always be engaged. I would remove the shifter knob and look inside and check the movement. It's very easy to do just don't accidentally punch yourself square in the mouth like I did when I was removing mine.
Wow, another scenario and that one seems dangerous as it can be bumped into reverse by accident!
Yup, dangerous like most of my old,odd fleet.MoVolvos wrote: 25 Sep 2024, 15:33.volvolugnut wrote: 25 Sep 2024, 15:22On my 2001 V70, the shifter button is permanently depressed by a botched button replacement. It allows shifting through all gears without pushing the shift lock button.br0dy519 wrote: 25 Sep 2024, 10:56 Might be the shifter knob button as well. It can break and get jammed causing the rod to always be engaged. I would remove the shifter knob and look inside and check the movement. It's very easy to do just don't accidentally punch yourself square in the mouth like I did when I was removing mine.
- br0dy519
Lugnut, if you have the metal rod version, it's possible it's too long and needs shaved down a bit. It's likely hanging up on the plastic, you can open it and look for scouring. Or just live on the edge.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
I have the other version.
I am happy on the edge.
volvolugnutr
volvolugnutr
- MoVolvos
.volvolugnut wrote: 25 Sep 2024, 19:27Yup, dangerous like most of my old,odd fleet.MoVolvos wrote: 25 Sep 2024, 15:33.volvolugnut wrote: 25 Sep 2024, 15:22
- 18 Replies
- 3275 Views
Last post by WhatAmIDoing
- 17 Replies
- 4672 Views
Last post by Clemens
- 4066 Views
Last post by lummert
- 13 Replies
- 6461 Views
- 1661 Views
