Heater core replacement - Brands? - 06 XC70
Has thanked: 2202 times
Been thanked: 1852 times
Many thanks, but it is for the 06 XC70 that is my son's, and not the S60 I worked on on the weekend. But they should be the same. I am in a monitoring mode on this just now. Not sure if or what is leaking if anything. I had been planning a coolant flush in the fall here, so to swap it out, this would be the time if there is an issue.
Appreciate the link!!
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
scot850 wrote: 01 Oct 2024, 10:42 Many thanks, but it is for the 06 XC70 that is my son's, and not the S60 I worked on on the weekend. But they should be the same. I am in a monitoring mode on this just now. Not sure if or what is leaking if anything. I had been planning a coolant flush in the fall here, so to swap it out, this would be the time if there is an issue.
Pinch the hoses from engine compartment, twist and pull to remove. They will be seized most likely, so it helps to wiggle/rotate them a few times beforehand. Place a quart container under one of the metal pipes going through firewall and blow compressed air in another: you'll get your old core and piping free of coolant almost entirely. Air compressor or shop vac in reverse both work equally well.
Been thanked: 504 times
Post by cn90 »
With Behr heater core NLA...
What brand is everyone using now?
Pros and cons?
Behr has been bought out by Mahle.
I found this Behr at Advanced Auto parts. Not cheap!
https://shop.advanceautoparts.com/p/beh ... icle=false
