Solid tappets are good for the life of car. In Volvo's opinion, you should be buying a new Volvo shortly after CPO expires. I.e. should happen before 100k milesMoVolvos wrote: 29 Sep 2024, 20:06 Nice work, however why is this not done or is it like the transmission fluidsuppose to be in spec the life of the car? Does VIDA give a mileage or time that this needs to be checked?
With 10k oil change intervals I see why Volvo switched away from hydraulic lifters. Solid tappets are not only cheaper, but they also don't mind working in that carbon-sludge mix you typically find under valve cover.
