2007 XC70: What should I know about a turbo-ed engine..?
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
erikv11 wrote: 03 Oct 2024, 13:49 Issues with the turbo itself are extraordinarily rare. Main things are (1) use good oil see vtl's post and (2) be sure to keep on top of PCV maintenance and (3) be prepared to replace the large diameter rubber intercooler hoses about 180k miles when the hoses start turning to mush. Oh and there are several extra vacuum lines, be on the lookout for older, failing, decayed rubber vacuum lines.
And two rubber diaphragms (in compressor bypass valve and wastegate actuator). And pretty much can guarantee, cast iron part of turbo has cracks. I've seen old 3 turbos (around 170-220k), all had cracks.
Has thanked: 311 times
Been thanked: 817 times
Good point, I remember the days most P80 cars had leaky CBV diaphragms, I suppose we are getting there for the P2 cars now, too.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Any info post on the rubber diaphragms? The XC70 has had a vacuum leak for 3 years and it sounds like somewhere near the turbo.
04s60 2.4
04xc70 2.5t
vtl
Post by vtl »
br0dy519 wrote: 03 Oct 2024, 19:45 Any info post on the rubber diaphragms? The XC70 has had a vacuum leak for 3 years and it sounds like somewhere near the turbo.
Pull the hoses from TCV and suck/blow air with your mouth, you'll find which one is torn.
br0dy519
Post by br0dy519 »
Oh I thought meant some kind of internal seal. You meant the yellow/blue/white tcv hoses
04s60 2.4
04xc70 2.5t
Been thanked: 4068 times
Two turbos, two NAs.
Very little maintenance difference. 5k oil changes, synthetic Castrol
The T5 has the highway boost
The S70 LPT has it all off the line.
The 2 NAs sneer at the turbos as they pass them at the fuel pump, getting > 30 mpg
I can just get to 29 mpg on the T5 if I keep the speed at 55 and no boost
vtl
Post by vtl »
abscate wrote: 04 Oct 2024, 03:32 Two turbos, two NAs.
I get 14 MPG in summer. Healthy 1 MPG more than in a pickup truck.
