Loud creak sound on takeoff. 1999 V70 Topic is solved
Markus123
Year and Model: 1999 2.5 TDI
Has thanked: 2 times
Been thanked: 3 times
Post by Markus123 »
Hi, can you help me diagnose, what makes this really loud creak when starting to drive?
ba070f16-2a2b-4843-8a5f-736099bb894a.mp4
(3.68 MiB) Downloaded 45 times
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2858 times
Been thanked: 1332 times
Post by matthew1 »
Because it's not rotational-sounding, I'd look at things that don't rotate: suspension bushings, engine mounts.
Does the angle of steering -- going the same low speed 0-3mph acceleration test -- change the sound? Does it seem like it's coming from up high or down low?
Are those 240 Turbo wheels?
Also -> Amazon link
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Markus123 wrote: 06 Oct 2024, 09:05 Hi, can you help me diagnose, what makes this really loud creak when starting to drive?
Sounds like brakes are binding? Sound only happens when you start to move and not with engine RPM. Turn the steering in the other direction at about the same angle and see if it makes the same sound?
Markus123
Post by Markus123 »
Solved. Replacing clutch fixed the problem. Here is one youtube short where same noise occur, also clutch replacement solved the issue
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Was it the release bearing making the noise?
Has thanked: 2205 times
Been thanked: 1852 times
I would look at a sticking brake caliper, parking brake cable, detached parking brake shoes and lastly a bent front brake dust shield.
Markus123
Post by Markus123 »
BlackBart wrote: 17 Nov 2024, 09:44 Was it the release bearing making the noise?
Will never know for sure. Did put new release bearing, clutch plate and disc.
Old release bearing had a lot more lateral play than new one tho.
In the video Iinked, in the comments he suggests old clutch disc was "polished", thus the screeching noise.
