NICE WORK! More bold than I and in my confidence do such for sure. Continue sanding and I would rotate alternating 180 degrees. Though heavy we are not perfect in our push, pull and slight pressing pressure as you slide the cylinder head across the sand paper. Any tolerance is made up by the gasket as you torque and that spot is where a leak would most likely occur.
Lapping (sanding) head down, within spec but still dirty. Keep going?
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
This is a turbo engine, it already has too much compressionvolvolugnut wrote: 09 Oct 2024, 14:38 If you remove too much thickness from the head, you can increase the compression ratio too much. This can cause ping and the need for higher octane fuel.
- 76 Replies
- 14896 Views
Last post by callahanoffroad
- 1046 Views
Last post by jmscdgn
- 1379 Views
Last post by oragex
- 11 Replies
- 2089 Views
Last post by bmdubya1198
- 873 Views
Last post by Chuck W
