1998 S70 -- ticking sound behind dashboard
mar601
Year and Model: 1998
Has thanked: 34 times
Been thanked: 5 times
Post by mar601 »
Only when the car is moving and I'm accelerating, do I hear a rapid ticking sound and thought it may have been a leaf in the vent (that's kind of what it sounds like) but when I put my head close to it it seems it coming from behind the speedometer. Any ideas? -- thanks
I've tried banging on the dash lightly but nothing seems to make it go away and it always sounds the same.
mar601
Post by mar601 »
actually I misspoke. it does it when the car is moving -- I dont have to be acccelaerating.
Has thanked: 2197 times
Been thanked: 1851 times
That is strange. It would suggest from the fact it only happens when you are moving it is coming from somewhere other than the cabin as it is hard to understand what is inside that only ticks when moving. The only thing I can think if is maybe the speedometer or possibly the famous gear teeth on the odometer failing?
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
scot850 wrote: 22 Oct 2024, 16:52 That is strange. It would suggest from the fact it only happens when you are moving it is coming from somewhere other than the cabin as it is hard to understand what is inside that only ticks when moving. The only thing I can think if is maybe the speedometer or possibly the famous gear teeth on the odometer failing?
Maybe for an 850, but the 98's are
all electronic as far as speedo/odo.
The only thing that I can think of that
moves back there would be an ECC
damper motor...
OP - Can you post some audio of your noise?
But why would it only tick when the car is moving. If it was an ECC fault it would tick all the time?
ScottieB
Year and Model: 98 S70 GLT 2.3
Post by ScottieB »
Only when moving or running ? Does the sound stop or slow when come to a full stop?
