low power up hill
Danonly55
Year and Model: 1996 850 sedan
Has thanked: 23 times
Been thanked: 4 times
Post by Danonly55 »
I have a 95 850 wagon, looks as if the catalic converter has been replaced, I have done the plugs and wires and cap and rotor. Car has 145k on it and a new timing belt recently. I have a feeling it might be the catalic converter Not sure if the correct one was put in prior to me buying the car. how can I check it and where can I get a new one.
Thanks
2014 Ford 3.5L ecoboost XLT
1995 Volvo 850 wagon GLE
Life is tough, but it's tougher when your stupid'
" John Wayne
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2866 times
Been thanked: 1332 times
Post by matthew1 »
No codes/CE light on?
Also -> Amazon link
Danonly55
Post by Danonly55 »
No codes, no lights.
" John Wayne
matthew1
Site Admin
Post by matthew1 »
The odds of a clogged/restricted/bad cat convertor throwing a code are much better than even... so let's back up...
Low power going up hills you mentioned. Low power accelerating? Anything else? Smoke? Stalling? Awful exhaust smells?
Also -> Amazon link
Danonly55
Post by Danonly55 »
It has low power accelerating, no smoke not stalling, kind of an odd smelling exhaust.
" John Wayne
matthew1
Site Admin
Post by matthew1 »
How much down on power would you estimate it is? If you're sure it's the cat causing the loss of power I'd look for a cat... well, this can get touchy with the state laws we all have now... but if you can, buy a used one, unless you have money, a jet, four mansions, a yacht or two and a helicopter. That's how much I'd guess you'd need for a new cat from the dealer, if they even still sell them.
Air filter ok?
Also -> Amazon link
Danonly55
Post by Danonly55 »
Creative and funny answer, Air filter is clean.
Thanks. When I get it figured out I will post results.
" John Wayne
Clemens
Has thanked: 501 times
Been thanked: 228 times
Post by Clemens »
wasn't there an easy method to measure the exhaust temp before and after the cat with an IR Thermometer? if the difference is too high, the cat is blocked.
1996 855 R,
2010 V70 D5,
matthew1
Site Admin
Post by matthew1 »
Excellent suggestion. Or use the poor man's IR thermometer: run it around good then look under there to see if it's glowing.
Also -> Amazon link
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
matthew1 wrote: 28 Oct 2024, 14:50 Excellent suggestion. Or use the poor man's IR thermometer: run it around good then look under there to see if it's glowing.
Accuracy is improved at night.
volvolugnutr
