Rev Hang 1998 C70 T5
tisho97
Year and Model: 1998 C70
Post by tisho97 »
Hey guys! I've had a nagging issue on my 1998 C70 2.3 T5 for quite some time - The idle stands high at 1000-1500 RPM and rev hangs under acceleration.
I get a P0505 code - Idle Air Control System Malfunction.
Things I've found and fixed:
1. Leaky fuel injectors O rings - Changed.
2. Bad coolant temp sensor - Changed with an OEM one.
3. Switched the TPS for a different one - no change
4. Switched the IAC valve for a different one that I also cleaned - no change
Vacuum lines seem fine but have yet to go under a smoke test.
After the repairs mentioned above, the car started running way better and the idle started behaving better, but the issue isn't really fixed as it is still high and rev hangs.
The thermostat also needs a change, but I don't know if that has anything to do with the idle issue at hand.
If you have any suggestions, let me know!
Cheers,
T
Has thanked: 2215 times
Been thanked: 1853 times
Have you checked the accelerator cable. They get dry and can also break strands which can cause them to stick. Also liberally lube the spring assembly at the motor end of the cable and make sure it is not sticking.
tisho97
Post by tisho97 »
scot850 wrote: 01 Nov 2024, 09:32 Have you checked the accelerator cable. They get dry and can also break strands which can cause them to stick. Also liberally lube the spring assembly at the motor end of the cable and make sure it is not sticking.
Hi Neil!
I've already checked the cable and it does not seem to stick, at least when the car is in one place.
Most recently, I did that check when cleaning the throttle body flap and it seemed that the flap closes quite easily when the gas pedal is released.
Just for laughs, start the car, and with the hood open, try to close the throttle flap further to see if the cable is fully home. You can adjust the cable length which will, or should adjust the idle too.
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
My 850 base had this issue after I had unplugged the throttle position sensor to move its cable while I was changing the starter.
After unplugging the TPS, again, and firmly replugging it, it settled down to around 1K, sometimes dropping to 900, which is where it's pegging. I also put a little dialectric grease on the contacts.
Usually on cold startup, it's around 750 where it should be but then immediately rises to 1k, so I'm still suspecting the TPS is causing the higher revs, but at 1k I'm leaving it there. I think the TPS housing can actually be loosened and rotated a bit, might be worth trying.
JimBee
Post by JimBee »
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
Definitely sounds like a vacuum leak at the intake manifold. Check all TCV lines, vacuum lines to the intake, vacuum tree, and gaskets.
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
