‘07 S80 3.2 - Front Brake Rotor Rust Welded to Hub
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Tried for brake job yesterday. Front brake rotor on above vehicle was rust welded to the hub. I have not done brake work to this car since we bought it. Acquired from a dealership who had maintained it. Am I really to believe dealer didn’t wire brush hub face and lightly coat with grease on last brake job? Who neglects to do that?
I pounded on the rotor with a rubber mallet hoping to shock loose — no joy.
Any removal tips before I resort to drive of shame to mechanic?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Apply heat to the rotor. Then apply hammer. if replacing rotor, use BFH (Big Freakin Hammer).
E Showell
Post by E Showell »
Ah, the blue point wrench. Only have a propane plumbing torch. Will that get things hot enough?
'95 855 auto (sold)
E Showell
Post by E Showell »
If I heat the rotor near the hub don’t I run the risk of liquifying the wheel bearing grease in the hub and having it run out?
'95 855 auto (sold)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Piece of wood and sledge hammer.
Also -> Amazon link
E Showell
Post by E Showell »
Nope. Calling in the pros for this one.
'95 855 auto (sold)
E Showell wrote: 02 Nov 2024, 10:33 Ah, the blue point wrench. Only have a propane plumbing torch. Will that get things hot enough?
The standard propane torch is not likely to generate enough heat to expand the rotor anyway. Let others deal with it.
E Showell
Post by E Showell »
Yeah. I’m no physicist, but I am pretty sure something like thermal mass is involved and I tried the plumbing torch. A bit like trying to put out the Chicago fire with a kiddie pool of water.
'95 855 auto (sold)
Has thanked: 2199 times
Been thanked: 1852 times
Soak the joint of the hub and the rotor with penetrating oil over night like PB Blaster.
The as advised give it a few good hits with a large hammer to shock it loose. Heat is good, but just as likely to damage the bearing.
where thick gloved and face protection in case the rotor sends out any splinters.
matthew1
Site Admin
Post by matthew1 »
E Showell wrote: 02 Nov 2024, 13:50 Nope. Calling in the pros for this one.
But... we are the pros. :shock:
Also -> Amazon link
