send it back , let them test it.
if its good then the problem is in the harness.
Limp mode, rough idle, multiple ECM codes - need help
krenekj
- Year and Model: Wife says too many
- Has thanked: 2 times
Another quick update.
My indie shop took another pass at the harness and signals while I was out of town. Everything checks out. When I returned home from my travels yesterday, I picked up an ETM from the local pick-n-pull which is compatible with my vehicle. It's a white-label one and has worked flawlessly for 20+ miles. The XeMODex warranty replacement ETM did not last nearly this long before failing.
I plan to put more miles on the car around town to be sure nothing happens. And if everything continues to be smooth, I'll ask XeMODex for another warranty replacement as there's nothing we can find wrong with the vehicle.
93 240 Wagon
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
Hey,
I was wondering if you ever sorted this out? I still have this ETM viewtopic.php?p=590079#p590079
krenekj
Thanks for reaching out. I'm still running the salvaged ETM. We've put about 2000mi on it, and no noticeable issues. That said, I could use a spare ETM. I'll send you a PM.
Also, XeMODex refused my second warranty claim. They assert that there are or were issues with the car that caused their ETMs to fail, even knowing the salvaged unit is working fine. I asked multiple times for further consideration and offered to split the cost of a new refurbished unit. They have not responded to any of my requests.
93 240 Wagon
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
