'02 V70xc I've removed the steering rack to replace a leaking line. I removed the pictured link which looks like it should telescope but it does not (at least by hand). Should it? Or is it designed to collapse in case of a crash?
Jim
Steering shaft link - telescope or not?
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
It does not telescope.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
BONINGERVAG
- Year and Model: 2006 XC70
Where does the distance slide when steering is in lower telescope position? Lowered subframe now wheel wont telescope down. Steering asembly slides, tilts fine when upper shaft link disconnected.
Vova585
- Year and Model: 01v70xc,2016xc70...
- Has thanked: 228 times
- Been thanked: 238 times
It is around $110. Please only buy Original volvo shaft. Not pro parts Sweden(PPS) My shaft from PPS lasted 3k and developed "clunking" at lower connection. Better also buy new oem bolt ($8 i think i paid)for lower connection(they are one time use, lot of people will disagree here). I dont remember exact torque spectrum for lower and top bolts, but hopefully nice experts will help with that data..
Inspect the rubber boot around the shaft. If the needle bearings inside of it are worn, rusty- better buy new oem one($55 or so) and be happy.
- Has thanked: 2200 times
I agree with Vova585 here. Steering is one of the most important parts of your car to save your life and be solid. Not cheap, but what is your life worth to you? Personally, I will use aftermarket parts in non-safety critical areas if available or the OEM supplier part over the Blue Box part.
Both the upper and lower bolts are replaced on reassembly per Volvo.
Upper bolt 30 Nm
Lower bolt. 25 Nm
Upper bolt 30 Nm
Lower bolt. 25 Nm
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
I used tools to pry open the lower part of this shaft’s clamp, assuming it was a pinch bolt. I saw then that there is a recess in the shaft where the bolt passes through. It needs to be “good and tight,” but it’s not clamping the shaft.
Now I have a tiny bit of on-center play in the steering, probably caused by opening up that joint. It’s very annoying, and you feel it as steering slop or as wandering as you go straight down the road. I may take this joint apart and see if some side shims will tighten it up, or just replace the shaft.
- 11 Replies
- 906 Views
Last post by jonesg
- 3599 Views
Last post by bluesguys80
- 15 Replies
- 5540 Views
Last post by Keithnysm
- 5212 Views
Last post by SuperHerman
- 683 Views
