SOLD 2007 Volvo S60 T5 M66 Manual 140K $6000 OBO Topic is solved
wasaab
Year and Model: 2007 S60 T5
Been thanked: 4 times
Post by wasaab »
My name is David Hauf and I’ve been a long time Volvo enthusiast, at around 2017 I was made aware of a 2007 Volvo S60 T5 which had been imported from Sweden from a coworker that knew I loved these cars, she told me it was for sale by her sister and brother in law in NH. I took a drive up with a trailer in tow and picked it up. I’ve had it ever since. It’s been well maintained and garage kept since in my possession. The paint is not perfect and has a few small scratches and dings and a few spots where tree sap from up north stained it. Overall the car is mechanically sound and it runs really good. Tons of power and the M66 shifts very smooth. At around 120k the transmission was replaced by the previous owner due to a problem with the original and the clutch and flywheel, throw out bearing and slave cylinder were all replaced. Timing belt and water pump were also done. It has an IPD 3” stainless turbo back exhaust that sounds amazing. I’ve replaced the full suspension with stock parts from FCP, the shifter bushings were all replaced and it is very tight, poly subframe inserts were installed, motor mounts replaced, brakes all around although a little rusty from sitting a bit but that comes right off after a drive. Coil packs and spark plugs replaced. It has an IPD aluminum skid plate. Turbo wastegate vacuum valve and silicon tubing installed, it has new e-brake cables installed, all new FAG wheel bearing all around, control arms, inner and outer tie rods, sway bar end links, has fairly new tires as well, I have a much longer list of maintenance items that can be provided. Unfortunately I’ve come to the point that I’ve collected too many cars over the last few years and I have to let it go. Let me know if there is any interest in this, I know it’s not an easy one to come by with the manual transmission and the desirable T5 2.4l motor. Everything works on it and it drives great. I'm located in CT.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Man what a nice looking S60 T5M. Beauty. GLWS.
Also -> Amazon link
wasaab
Post by wasaab »
Thank you, yeah I hate to let it go but can't afford to keep everything anymore. It's not perfect there are some flaws, but for its age it's pretty nice. I just realized these pictures also don't show it with the skirt trim on. It does indeed have it, I had taken them off to get re-painted because there were a bit chipped up and scratched just in case anyone was wondering.
2001s60T5m
Year and Model: 2001 S60 T5
Post by 2001s60T5m »
Still for sale? If so, please DM me.
wasaab
Post by wasaab »
Sorry didn't see this in time. Unfortunately it just sold a couple days ago.
SummumPL
Year and Model: Volvo S60 2.5T Summ
Post by SummumPL »
My friend what a wonderful car, can you tell me more information in private message. This is usual colour willow green metallic !
