Hello!
I just bought a V70 2.4T 2002 that won't start, it gave codes related to the camshaft position sensor and the crankshaft position sensor. I swapped them out for new parts but no luck...
I hear the fuel pump priming, there's fuel in the fuel rail, this example did not come with a PEM or FPS, only a fuel pump relay as far I know (plastic tank).
Like I said, I sprayed it with starter fluid into the intake and the car came to life! But only for a second or two until it returned to the state it's in.
It cranks but doesn't show any sign of life without the starter fluid. No codes on the OBD2 scanner after i changed the sensors, so I would really appreciate some help!
2002 V70 2.4T only starts with starter fluid?
- Has thanked: 987 times
- Been thanked: 1076 times
If it does not start without starter fluid, it is surely a fuel supply problem. Start with fuel pressure test at the engine fuel rail.
- 1760 Views
Last post by doublebug
- 36 Replies
- 5998 Views
Last post by bobbycgolf
- 1762 Views
Last post by jpac
- 1372 Views
Last post by SventheS70
- 969 Views
