I’ve put MaxLife in an Aisin U151E transmission (Lexus) and experienced the same. That unit uses T-IV, which is more similar and same viscosity as the Dex-II and Dex-IIIF the 850 used when new.canicallyourose wrote: 05 Sep 2024, 23:51 interesting observations about the viscosity differences between fluids. i used maxlife in my 850 transmission once and noticed some hesitation afterwards - maybe the lower viscosity was the culprit? switched back to oem fluid and it seemed happier.
I still like and use MaxLife, but only in vehicles designed for low viscosity fluids like Dex-VI or Toyota WS (3324, like newer Volvos). I especially like it instead of WS as it has been a problematic fluid with premature failure when it first came out.
