Loud creak sound on takeoff. 1999 V70 Topic is solved
- Has thanked: 2864 times
- Been thanked: 1332 times
Because it's not rotational-sounding, I'd look at things that don't rotate: suspension bushings, engine mounts.
Does the angle of steering -- going the same low speed 0-3mph acceleration test -- change the sound? Does it seem like it's coming from up high or down low?
Are those 240 Turbo wheels?
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.Markus123 wrote: 06 Oct 2024, 09:05 Hi, can you help me diagnose, what makes this really loud creak when starting to drive?
Sounds like brakes are binding? Sound only happens when you start to move and not with engine RPM. Turn the steering in the other direction at about the same angle and see if it makes the same sound?
- Has thanked: 2209 times
I would look at a sticking brake caliper, parking brake cable, detached parking brake shoes and lastly a bent front brake dust shield.
Markus123
- Year and Model: 1999 2.5 TDI
- Has thanked: 2 times
- Been thanked: 3 times
Will never know for sure. Did put new release bearing, clutch plate and disc.
Old release bearing had a lot more lateral play than new one tho.
In the video Iinked, in the comments he suggests old clutch disc was "polished", thus the screeching noise.
- 706 Views
Last post by JRL
- 993 Views
Last post by vrracer
- 976 Views
Last post by Snoopy1428
- 1670 Views
- 328 Views
