Urgent Help Finding Oil Leak Topic is solved
BeerDeer
Year and Model: 1996 and Volvo 850
Has thanked: 2 times
Been thanked: 3 times
Post by BeerDeer »
Hi all.
I have a Volvo 96 850 (Automatic).
It always had a oil leak since I bought it and now I used Oil Saver from Liquid Moly and it loses while driving like 2 cups of oil. :(
Check: Image
The oil leak comes from driver side. Top part. Check: Image
Here´s a video (upside down) of oil "dripping"...
Where is it coming from?
BeerDeer
Post by BeerDeer »
Another view;
Its recorded upside down. Liquid Moly made it worse it seems. What do you guys think?
Has thanked: 2200 times
Been thanked: 1852 times
Could be the rear main seal for the crankshaft. Can you take a picture or video further back under the car? When it is this close it is hard to see where you are pointing the camera.
BeerDeer
Post by BeerDeer »
scot850 wrote: 23 Nov 2024, 16:30 Could be the rear main seal for the crankshaft. Can you take a picture or video further back under the car? When it is this close it is hard to see where you are pointing the camera.
Hi I can't pic under. I would need to lift the car. I don't have one lifter available.
Check attached pictures..
Thank you for your kind help.
I'm also using 5W-40 premium brand oil.
BeerDeer
Post by BeerDeer »
I rotated the video so it's easier to understand.
VID-20241123-WA0029_1.mp4
(26.37 MiB) Downloaded 48 times
Is it the rear camshaft seals? If it is, then have you checked for crankcase pressure? If not, I would do that urgently. Simple to do.
Rubber/latex glove. Remove the oil filler cap and use rubber bands to hold the glove in place over the oil filler hole.
Either start the car or have someone do it for you to make sure the glove does not come off.
If the glove lifts/inflates at idle then the crankcase (PCV) system is clogged and needs cleaning/relacing soon as it will blow all the seals out.
First to go are the cam seals or the crank seals or both.
If you rev the engine and the glove inflates further then you do have a big issue and it needs done ASAP.
If the glove does not inflate or when rev'd the glove looks like it is being sucked inward then this is not the issue.
Cam seals can go out without the PCV being clogged.
Been thanked: 4065 times
It’s coming ftom up high, so it’s probably just the cam seal
Check crankcase pressure s over per Neil.
Then it’s a $5 seal and two hours labour to fix , plus cleaning!
BeerDeer
Post by BeerDeer »
scot850 wrote: 23 Nov 2024, 23:36 Is it the rear camshaft seals? If it is, then have you checked for crankcase pressure? If not, I would do that urgently. Simple to do.
Thank you so much for your kind help and guidance. Unfortunately, I’m not very experienced when it comes to cars, so I’m unsure if the issue involves the rear camshaft seal or another component.
I spent about an hour yesterday trying to locate the source of the leak, and I was able to identify the area where it’s dripping. I’ve marked it on the attached picture for your reference. Access to the area is quite challenging due to cables and plastic obstructing the way.
I’ll perform the glove test as soon as possible to check for any crankcase pressure issues. If the glove test results indicate no pressure problem, what could be the likely cause of the leak?
BeerDeer
Post by BeerDeer »
abscate wrote: 24 Nov 2024, 01:46 It’s coming ftom up high, so it’s probably just the cam seal
Thank you. I will do this now and maybe take new pictures.
BeerDeer
Post by BeerDeer »
Hello,
Glove inflated... and I isolated the area further. There appears to be a persistent drip under a specific section. Please refer to the attached images for more details.
Thank you for your attention to this matter.
Best regards
VID-20241124-WA0010.mp4
(3.72 MiB) Downloaded 46 times
