J2534 is pass-through, nothing fancy. I use it in a similar hw: https://github.com/vtl/volvo-ddd And there's a "teensy" branch. And the PCB https://oshwlab.com/v.mayatskih/volvo-ddd2_copy which looks somewhat similar to the cracker. Adding J2534 support is mostly writing a driver for OS of your choice.Treur wrote: 03 Dec 2024, 05:17 So far I have only one idiotic idea in my head - to add the j2534 protocol to your cracker.![]()
Vida CEM swapping
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Treur
- Year and Model: 2007 V70
- Has thanked: 3 times
- Been thanked: 7 times
J2534 is not just driver. The device must process driver commands.vtl wrote: 03 Dec 2024, 05:43J2534 is pass-through, nothing fancy. I use it in a similar hw: https://github.com/vtl/volvo-ddd And there's a "teensy" branch. And the PCB https://oshwlab.com/v.mayatskih/volvo-ddd2_copy which looks somewhat similar to the cracker. Adding J2534 support is mostly writing a driver for OS of your choice.Treur wrote: 03 Dec 2024, 05:17 So far I have only one idiotic idea in my head - to add the j2534 protocol to your cracker.![]()
But I don't think it's don't worth it. If we need a real PIN so much, we can use dice to find a PIN by UDS, download SBL, download flash and get it. The question is - why do we need it if we can already log in by UDS!?)))
P.S. How can I access this forum by PC? Cloudflare can't check me)))
rolkat5
- Year and Model: Volvo S80 2004
Hello everyone. I've got this Cem-B. 2003MY. But seems like this cem is little bit different and i cant find schematics where to solder wires. Can anyone help ?
Edit: nvm, i was in a rush and seems like i took a REM instead of CEM from junkyard
Treur
It's not CEM. REM)))rolkat5 wrote: 03 Dec 2024, 08:12 Hello everyone. I've got this Cem-B. 2003MY. But seems like this cem is little bit different and i cant find schematics where to solder wires. Can anyone help ?
scaro
- Year and Model: Volvo&Audi
- Has thanked: 14 times
Is that really a Cem? isnt it Rem, could be that im wrong.
Anyway noticed that i needed to use win7 for UDStool(6byte). Now code show up correctly when writing it in prog. In my eager i even forgot to add 120ohm on canbus... added them. Cem clicks now but still cant read the file, it says "wrong code"
As i said before i havnt a clue if it should be possible to read it this way
244 Turbo (86K miles) 1983
242 B230FK, Rollcage, LSD 1984
244 B21A with R-Sport Turbo-kit 1980
A5 2.0TFSI Quattro Conv. 2012
A4 1.9TDI 1997 BV43, 11mm vp37, 0.26 nozzels, 6speed, A8 brakes front, S4 discs/calibers rear
A4 1.9TDI 1998 Daily
scaro
Yes that what i say
scaro
Its in this thread. Think its on side 298 or something. Havnt used exact that pinout but try it
- 9135 Views
Last post by RickHaleParker
- 9021 Views
- 27 Replies
- 28107 Views
Last post by cn90
- 10 Replies
- 10472 Views
Last post by jonesg
- 5635 Views
