Hello all,
I hope everyone is doing well,
I have an interesting issue i noticed today when i was underneath the wagon at first i was fixing the right front fog lamp it has not worked in a good while i have Led Headlights and Led fog lamps the right side wiring got green corrosion on the plug and several other areas of the wiring so i removed all that mess and just installed a regular old yellow fog lamp on that side its cheesy i know but its fixed for the time being.
The other Main issue is when underneath the car i though hey i have another transmission Torque mount let me go ahead and change that it has not been done in along time.
when i hooked up my socket and ratchet i noticed the bolts were loose like finger tight i thought what in the Hell????
then i noticed on the back of the mount that bolts into the transmission the bolt was missing and a big chunk of aluminum was gone also like someone over tightened the bolt and broke off the bolt hole and bolt.
i dont know when this happened i had my transmission rebuilt some years back at a place in Torrance california called Atlas transmissions this guy is a volvo specialist and he did an amazing job rebuilding my transmission.
he did all this work including installing a new valve body and solenoids also for the price of 1400.00 i know this is unheard of because i have checked around a few places in Texas and other areas and people tell me yea uhhh 3500.00 or more.
back to the Torque mount i got the back bolt out barely it was on there really tightly i removed the old mount and it was a little worn out i installed the new mount and tightened the bolts onto the subframe. then i tightened the back bolt everything seems ok should i worry about that one bolt thats missing along with the chunk of aluminum thats also missing? here are a few pictures for yall
Transmission Torque Mount bolt hole broken off
- Has thanked: 1843 times
- Been thanked: 1710 times
While less than ideal, can you use a longer bolt? How far do the threads go into the broken hole?
Neil
Neil
The bolt is the same as the one beside it.
- Has thanked: 1502 times
- Been thanked: 3817 times
You guys down South suck. Ive never seen the clamp for the power steering lines with a torx screw that wasnt a hunk of rust. I dont even get the Torx set out, I just reach for the grinder
Load that hole up with grease, put a bolt in it, and drive it another 200k miles
fitz548
- Year and Model: 1998 V70-XC
- Been thanked: 7 times
I looked up the part number on the bolt and turns out its an M10 and so i ordered some M10 grade 8.8 zinc plated bolts from amazon they will be here in a few days-
yea as far as the clamp on the power steering lines i never really paid must attention to the bottom of the car most of the time when i was living on the west coast i had a shop perform all of the repairs its only now some years later that i have a house and a good size garage and i am fixing everything myself.
This car was originally from PNW so i was not sure what was done to it over the years.
fitz548
Ok this is fixed now i actually used a Depstech Borescope to look inside the bolt hole and the threads were clean. i think maybe the bolt fell out cause it might have come loose at one point.
I used a bolt that was about 1/4 inch longer and i was able to secure that bracket i tried using a longer bolt but it bottomed out in the housing so this other size was good enough now on to the next task.
Thanks for all your help everyone.
- 613 Views
Last post by GreenMagicMan
- 16 Replies
- 4216 Views
Last post by 1337
