Morning All
I have a 2003 xc70 has developed a coolant leak. I wanted to isolate the heater core. Can I put hose clamp pliers on both hoses and still use the car ?
Thanks P
Coolant leak
Porkchop32
- Year and Model: 2003 xc70
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
coolant has to circulate through the dash whether the heat is on or off.
Your weather is mild, I'd be tearing into it.
We just got another 4 inches, -2F last night.
- Has thanked: 1611 times
- Been thanked: 4072 times
I don’t think you can clamp those off tight enough to have zero pressure in the core, it will still leak
Better to pull the ends and bridge with heater hose. It’s 5/8 hose on p89s , not sure about P2 models?
Anyone?
Anyone?
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Heater core replacement can be eventful with driver seat in place, but without driver seat can be a joyful work space.
Alawys use Volvo clips and o'rings, more here viewtopic.php?t=105361
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
200 lbs me did 3 heater cores without removing the seat. First time I removed the steering column, but later figured out how to route the new core around without damaging it.xHeart wrote: 12 Dec 2024, 08:05 Heater core replacement can be eventful with driver seat in place, but without driver seat can be a joyful work space.
xHeart
Same here vtl, 3 in my experience.vtl wrote: 12 Dec 2024, 08:23200 lbs me did 3 heater cores without removing the seat. First time I removed the steering column, but later figured out how to route the new core around without damaging it.xHeart wrote: 12 Dec 2024, 08:05 Heater core replacement can be eventful with driver seat in place, but without driver seat can be a joyful work space.
The brake booster replacement experience with folded driver seat placed over the rear seat was an ahha moment.
Again, my approach is to make working a joyful and cussless experience.
This item, brake light switch must be handled gently during a heater core service...
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
I mean the fins on mine did bend on the lower part near the corner, but not enough in my opinion to cause significant issuesvtl wrote: 12 Dec 2024, 08:23200 lbs me did 3 heater cores without removing the seat. First time I removed the steering column, but later figured out how to route the new core around without damaging it.xHeart wrote: 12 Dec 2024, 08:05 Heater core replacement can be eventful with driver seat in place, but without driver seat can be a joyful work space.
jrschwit
- Year and Model: '01 V70 T5, '02 V70
- Has thanked: 12 times
- Been thanked: 8 times
P,
Whether your goal is to remove the heater core from the coolant system to either eliminate it as a source of a leak or to delay core replacement, it will not be a problem operating the car with the heater hoses blocked. Whether you isolate the core by pinching the hoses with suitable clamps or disconnect and bridge them does not matter. I would consider the flexibility of the hoses before I clamped them, though.
My '03 V70 na has very supple hoses next to the firewall and I would not hesitate to tightly clamp them. Though it is correct that hot coolant continuously flows through the heater core, removing it from the coolant system will, if anything, marginally improve the system's overall efficiency.
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
"Heater core replacement can be eventful with driver seat in place" Eventful!xHeart wrote: 12 Dec 2024, 08:05 Heater core replacement can be eventful with driver seat in place, but without driver seat can be a joyful work space.
compares well to medieval torture levels of pain. Removing the seat is well worth the extra effort if spending any amount of time under the dash.
Here's what under dash repair pain inspired me to do for another upcoming under dash repair. I also now remove the seat every time.
- 16 Replies
- 4508 Views
Last post by granite
- 16 Replies
- 5417 Views
Last post by lcc014
- 1659 Views
Last post by DanSC
- 4140 Views
Last post by SuperHerman
- 9 Replies
- 4522 Views
Last post by rspi
