850 control arm bushes x2
minny
Year and Model: 850
Post by minny »
Hi I have removed the two alloy bodied control arm bushes from the car and ready to refit the new ones.
How to I know where the bush sits relative to the arm to torque it up?
Once refitted its hard to get to the bolts.
Thanks
Has thanked: 2200 times
Been thanked: 1852 times
Should have measured the position before removing!
They should be fairly central in the holes. This picture may help as you can magnify it:
https://www.rockauto.com/en/moreinfo.ph ... 01&jsn=974
Once you have one in, you can use the 2 mounts they fit into as a guide that they are going to fit.
Good Luck!
minny
Year and Model: 850
Post by minny »
Hi thanks but its the Rear control arm bushes that I have replaced, the two transverse arms run left to right and they enter into the alloy bodied bush
where they enter into the bush theres a bolt but theres no access once fitted in, how do you get them into correct position to torque up?
Thanks!
minny
Year and Model: 850
Post by minny »
Circled in red is the bolt which i require assistance to torque up,
There is no access to the bolt once each mount is in place inside the rear subframe.
I can torque up the bolt with the arms pulled out but what position do they sit in as they spin on the mounting.
Thanks all
minny
Year and Model: 850
Post by minny »
circled red is bolt in question
Sorry, are these the rear axle adjustment bushes you are talking about? I was mistaken as you said control arms which are at the front!
On the RHR adjuster (for the left wheel toe in/out) You will likely have to remove the rear sway-bar to get into the bolt head.
On the LHR I thought you could get access with an extender bar or wobble bar. Been a long time since I did a FWD car.
minny
Year and Model: 850
Post by minny »
This has been resolved.
I left them finger tight then reassembeld the whole back end, dampers springs delta mounts
I loaded the rear suspension to normal ride height and marked the bush relative to
each transverse arm with a line of paint
I then stripped everything again and swung both arms out and torqued them up ensuring my marks lined up with a bit of loctite also.
All refitted now
Well done and great thinking on this!
