Vida CEM swapping
scaro
Year and Model: Volvo&Audi
Has thanked: 14 times
Post by scaro »
T5Luke wrote: 27 Apr 2023, 04:40 Here this is minimum connection to CEM on bench.
On D connector:
Green: HS CAN-L to pin 14 OBD
White: HS CAN-H to pin 6 OBD
Grey (pin 6 ): GND
Yellow (pin 8 ): +12V
Blue (pin 15 ): +12V
Also it needs +12V on the both big connectors (big green power socket)
I just have 1 x 100 Ohm between both can lines, on bench, that is enough for me...
Pin 8 and 15 in this pic a belive is for key pos. 1&2
danthe88 wrote: 03 Dec 2024, 10:18 Guys, is there some diagram how to connect teensy to CEM 30765643 on the bench?
I used only these pins to crack with Teensy:
Pin 48 (OBD14) and 33(OBD6) as HS can (120ohm)
Pin 55 (OBD11) and 40(OBD3) as LS can (120ohm)
Pin 6 (OBD4-5) GND
2 big pins on other side to +12V
244 Turbo (86K miles) 1983
242 B230FK, Rollcage, LSD 1984
244 B21A with R-Sport Turbo-kit 1980
A5 2.0TFSI Quattro Conv. 2012
A4 1.9TDI 1997 BV43, 11mm vp37, 0.26 nozzels, 6speed, A8 brakes front, S4 discs/calibers rear
A4 1.9TDI 1998 Daily
danthe88
Year and Model: 2006 XC90
Post by danthe88 »
Tnx, I will try for the weekend, I have tried using OBD but after decoding first 3 bytes it failed to bruteforce the rest... I don't have a garage so I will have to remove CEM and to let it run for 24hrs or so...
rkam
Year and Model: 14473_96090_XC7007
Has thanked: 5 times
Been thanked: 25 times
Post by rkam »
Treur wrote: 03 Dec 2024, 06:13
vtl wrote: 03 Dec 2024, 05:43
Treur wrote: 03 Dec 2024, 05:17 So far I have only one idiotic idea in my head - to add the j2534 protocol to your cracker. :wink:
J2534 is pass-through, nothing fancy. I use it in a similar hw: https://github.com/vtl/volvo-ddd And there's a "teensy" branch. And the PCB https://oshwlab.com/v.mayatskih/volvo-ddd2_copy which looks somewhat similar to the cracker. Adding J2534 support is mostly writing a driver for OS of your choice.
J2534 is not just driver. The device must process driver commands.
But I don't think it's don't worth it. If we need a real PIN so much, we can use dice to find a PIN by UDS, download SBL, download flash and get it. The question is - why do we need it if we can already log in by UDS!?)))
P.S. How can I access this forum by PC? Cloudflare can't check me)))
As VTL mentioned, J2534 is the communication protocol between a software application and a driver. The communication between the driver and the interface can be whatever the hardware designer wants.
Some time ago Olaf started making a driver to use an Arduino as a J2534 device in Vida. Since I already had a Lawicel CANUSB, he started using the Lawicel protocol between the device and the driver. This way the same driver could be used for the Arduino and the Lawicel.
https://github.com/hackingvolvo/SardineCAN-Win32
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
rkam, do you personally know Olaf or perhaps know why he disappeared? He was my inspiration to make my own tools, maybe even the catalyst to start digging into the cars.
In the late 2022 I started making my own version of Sardine-can to support ethernet proxy between RPI and VIDA. I dropped the project due to timing constraints(VIDA has a 60ms timeout).
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Same for Olaf. Sardine-can was a lot of inspiration.
rkam
Post by rkam »
Sadly, the last email I got from him was mid january 2013.
I only knew him as Olaf.
Treur
Year and Model: 2007 V70
Has thanked: 3 times
Been thanked: 7 times
Post by Treur »
rkam wrote: 04 Dec 2024, 11:36
What does Lawicel have to do with it? It's a primitive protocol based on AT commands. I used to program Volvo units with a homemade cable on Atmega8 with this protocol.
rkam
Post by rkam »
I could have used Kvaser or Peak Can as example, but I chose Lawicel because:
And I do not fully agree with your comment below:
Yes, the device must process driver commands, but they do not have to be J2534 commands.
They can be Lawicel commands or other commands over serial, bluetooth (serial), USB, TCP or something else.
scaro
Post by scaro »
I managed to read the older CEML with M30835FJ using TTL and FDT4.09. But the flash is corrupt (not from the reading)
Parts with logincode, encryptioncode, Vin and config is intact in flash it looks like.
Think its the only thing that needs transfering to a working flash?
External EEprom is also corrupt it has loosen part with keys and sync.
Someone have a flash from a CEML with number 30728356 to share? Or both Flash and xEeprom.
scaro
Post by scaro »
The Flash isnt corrupted as i stated before. I have got some to compare with and looks good.
The "only" thing now is to fix the sync and keys in xEeprom.
Want to thank you that sent me files to compare with, you know who you are.
