99 S70 GLT Engine B5254T [Vacuum leaks, hoses, Snorkel] Topic is solved
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Grantkat wrote: 09 Jan 2025, 05:38 I will rent a fuel gauge set up and test the fuel pressure.
Another question - any idea about why the engine was chugging and "dieseling". That seems beyond a fuel delivery issue?
If it's getting starved for fuel, it'll act like this and give you no throttle response. It will also come back all at once when the system repressurizes.
As mentioned above, I also forgot about the DBW system in the 99-00 P80s. Those could cause some issues like you're seeing if you've got a buggy unit that's giving irregular readings.
Grantkat
Year and Model: 1999 s70 GLT
Has thanked: 59 times
Been thanked: 54 times
Post by Grantkat »
Hi Caesium,
can you please explain what a sweep test is and how its performed?
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
Grantkat
Post by Grantkat »
quick update. I rented a fuel pressure test kit unfortunately it did not have the correct size adaptor for the schrader valve on the S70. So I used a tire gauge.
I released the pressure at the valve, turned the key to on 2 times without starting and got 20 PSI.
I repeated the test and got 20 PSI
1999 S70 GLT ~193k
2014D VIDA/DICE
Grantkat
Post by Grantkat »
just tested running - 55+ PSI at idle.
1999 S70 GLT ~193k
2014D VIDA/DICE
Been thanked: 4071 times
Grantkat wrote: 09 Jan 2025, 12:12 just tested running - 55+ PSI at idle.
That looks good.
Grantkat
Post by Grantkat »
Ok so I have eliminated the fuel pump and fuel pump relay.
So what to look for next?
Also - question: I double checked by vacuum lines to make sure all were in place and secure, I also checked all the connectors MAF etc to make sure no sensor was disconnected or loose. While doing this I noticed something:
There is a pipe from the air filter box going to the back of the engine and down. I cannot see where it connects as there are things in the way, but where ever it connects back there it is loose ie can be jiggled/moved - is that normal?
1999 S70 GLT ~193k
2014D VIDA/DICE
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
That pipe goes down to your turbo. It is secured, or should be, with a hose clamp. If it is loose, then unmetered air is getting into the system.
No bueno...
1999 V70 GLT
Grantkat
Post by Grantkat »
ah ok thank you. I will get under the car and see what gives
1999 S70 GLT ~193k
2014D VIDA/DICE
Grantkat
Post by Grantkat »
can it be accessed from underneath?
1999 S70 GLT ~193k
2014D VIDA/DICE
Chuck W
Post by Chuck W »
Grantkat wrote: 09 Jan 2025, 15:34 Ok so I have eliminated the fuel pump---
Not necessarily.
If you're not monitoring FP while driving, you really haven't ruled it out. It could idle for hours and not skip a beat. It's a PITA, but you need to see what it does when the engine acts up.
It was also mentioned to investigate the electronic throttle.
