Skandix order to USA June 2025
Has thanked: 1609 times
Been thanked: 4064 times
If you need parts from Skandix Im ordering some engine stuff and you can ride on my 100 EU shipping from GER to USA, I can ship to you from NY using USPS at the usual flat rate box charges. Lets use this thread for the list, and PM for payment info
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Well being the big spender that I am, I'll take 2 of the valve spring retainer washers. Not that I'd ever lose one.
1999 V70 GLT
Sveedy
Post by Sveedy »
And the lost washer has been found ! Amazing what distance a little piece of metal can fly.
So Thanks everyone for your help. At least I learned about the change in valve stems in '99.
1999 V70 GLT
Ttrojan
Year and Model: 1991 740
Post by Ttrojan »
Have you ordered yet? In need of this #1268660 fork guide rail for my 740.. might as well get 2each
And this #1268661 fork guide rail front 2each
Not yet. Added
order submitted
Ttrojan wrote: 28 Jan 2025, 15:00 Have you ordered yet? In need of this #1268660 fork guide rail for my 740.. might as well get 2each
Pm me your address so I can send these to you!
Next Skandix order, June 2025
Anyone want brake rebuild kits?
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Did we ever find a source for the eccentric bolts on the rear end of the '99 V70 XC AWD? I'm guessing someone makes them for other purposes - trick is tracking them down.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
wizechatmgr wrote: 08 Apr 2025, 07:46 Did we ever find a source for the eccentric bolts on the rear end of the '99 V70 XC AWD? I'm guessing someone makes them for other purposes - trick is tracking them down.
Mercedes also uses eccentric suspension bolts. What are the chances they are the same? Anyone have some dimensions?
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Thinking out loud - could a thick washer with an eccentric hole be welded to the appropriate bolt head?
