Is this cam timing set correctly?
That intake needs one more tooth tweak, ccw when viewed from front of engine
777funk
- Year and Model: 240
- Has thanked: 11 times
I edited the photo a little bit and it turns out to be about 4.5-5 degrees off. How many degrees is one tooth on the wheel?abscate wrote: 19 Jan 2025, 01:11 That intake needs one more tooth tweak, ccw when viewed from front of engine
I think it’s 46 teeth I the cam pulley, so that’s about 8 degrees per tooth. So, one tooth
