- DennisCA
- Year and Model: 1996 850
- Has thanked: 6 times
- Been thanked: 67 times
Fuel pump relay works, there is another relay for the injectors near the fan, this also works. I am also getting a spark. The car is cranking and cranking, sometimes it almost starts. I do get a gasoline smell too so I think the injectors are doing their job. I suspect I've gotten lawnmower syndrome.
- DennisCA
I got the engine started. I put oil in the cylinders and charged the battery. I also filled oil into the engine as it seemed low. Then further looking and it appears I got an oil leak in the engine, the bottom of the pan is wet and it looks like the front of the engine block somewhere under the intake might be the source. Perhaps the PCV system?
Photo from below
Photo from below
More likely its a cam seal with that amount of oil - thats a lot. Clean it all off so you can try track the flow.
- Has thanked: 316 times
- Been thanked: 531 times
Yeah you’ll definitely need to clean it up a little and get a good look up in there. Could be PCV, a cam seal, dipstick tube seal, oil pan, etc.
- nickelghandi
- Year and Model: 1998 Volvo S70 GLT
- Has thanked: 14 times
- Been thanked: 3 times
I fixed a massive vacuum leak on my 1998 S70 GLT to stop it from stalling and misfiring.
-Nick
NC855R
- Year and Model: 1997 850 R
- Has thanked: 46 times
- Been thanked: 28 times
Cold weather, old tired lift gate struts
Now replaced with new strong ones and working a charm
PSA use supports on the lift gate when removing even 1, ask me how I know.
RedBrickCollector
- Year and Model: 1997 850 T-5 Wagon
- Has thanked: 40 times
- Been thanked: 29 times
Tried replacing the copper washers for my turbo coolant inlet (twice). Still leaks, I think I have a cracked pipe.
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
Sat and idled in the T5 in my driveway to lower my BP after my brand new New Beetle driver window regulator self-immolated and undid 4 hours of work and 2 years of waiting. My independent will get the do-over. New regulator $800
On the bright side, City got crushed by Arsenal 5-1
