DennisCA
Year and Model: 1996 850
Has thanked: 6 times
Been thanked: 67 times
Post by DennisCA »
Fuel pump relay works, there is another relay for the injectors near the fan, this also works. I am also getting a spark. The car is cranking and cranking, sometimes it almost starts. I do get a gasoline smell too so I think the injectors are doing their job. I suspect I've gotten lawnmower syndrome.
DennisCA
Post by DennisCA »
I got the engine started. I put oil in the cylinders and charged the battery. I also filled oil into the engine as it seemed low. Then further looking and it appears I got an oil leak in the engine, the bottom of the pan is wet and it looks like the front of the engine block somewhere under the intake might be the source. Perhaps the PCV system?
Photo from below
Been thanked: 4065 times
More likely its a cam seal with that amount of oil - thats a lot. Clean it all off so you can try track the flow.
DennisCA
Post by DennisCA »
I suspect the 850 will be taking an extended vacation now then, good thing I got a backup car ready. I suppose I should be worrying about the PCV system again.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Yeah you’ll definitely need to clean it up a little and get a good look up in there. Could be PCV, a cam seal, dipstick tube seal, oil pan, etc.
DennisCA
Post by DennisCA »
I believe if it's the cam seal, it should be easy to spot. Oil would be coming down from high to to speak, whereas a dipstick or oil pan leak would be be lower down.
nickelghandi
Year and Model: 1998 Volvo S70 GLT
Has thanked: 14 times
Been thanked: 3 times
Post by nickelghandi »
I fixed a massive vacuum leak on my 1998 S70 GLT to stop it from stalling and misfiring.
-Nick
NC855R
Year and Model: 1997 850 R
Has thanked: 46 times
Been thanked: 28 times
Post by NC855R »
Cold weather, old tired lift gate struts :( Now replaced with new strong ones and working a charm :) PSA use supports on the lift gate when removing even 1, ask me how I know.
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 29 times
Post by RedBrickCollector »
Tried replacing the copper washers for my turbo coolant inlet (twice). Still leaks, I think I have a cracked pipe.
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
Sat and idled in the T5 in my driveway to lower my BP after my brand new New Beetle driver window regulator self-immolated and undid 4 hours of work and 2 years of waiting. My independent will get the do-over. New regulator $800
On the bright side, City got crushed by Arsenal 5-1
