A "REAL" fix for the 850 wiper arms
This topic is in the MVS Volvo Repair Database » Wiper Arms - Not Contacting Hard Enough?
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Between the drivers side arm hitting the edge of the hood, and the passengers side park position being so high above the cowl that it was never out of sight, I switched to Dodge Shadow wipers. I remember having to do some minor modification on the drivers side, and I use two different size blades. Since most of my driving is obviously with the wipers off, the passengers side always sticking up there bothered me.
Disappearing wipers had been around for years, so I don't see how that got by the designers at Volvo. The car look way better from inside or out with them hidden.
1999 V70 GLT
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 278 times
Been thanked: 86 times
Post by hausmeister »
I read your comment about that, but I have never seen a Dodge Shadow :D
Wikipedia says it was called a Chrysler ES in Europe, but I can't find any wiper arms for that. It is even older than the 850ies, and I have never seen one.
Unless some newer models also use them - like this? https://www.ebay.at/itm/395732106129
I'd need some partnumber to look for that.
850 T5-R '95 auto Image
Sveedy
Post by Sveedy »
Yes, not easy to find anymore. And I don't know if aftermarket is any help. They were early to mid 90's over here.
Something else I should probably keep an eye out for when picking around in the yards. They must have been used on other cars, as I can't see them having a special wiper arm made for a budget car.
1999 V70 GLT
SCJ
Post by SCJ »
The V70 arms are NOT a drop in replacement. End of story.
No matter if you swap them side-to-side or how or far down you force then the drivers will always hit the hood. Even adjusting the hood to its highest level does not prevent contact of the drivers side wiper arm at the near vertical position.
The only real solution is to grind back the stops of the stock wiper arm.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I found a new 850 wiper arm (9151087) at Voluparts and installed that last summer... looks great and works great for now. I know I'll have to grind back the stops and/or bend the arm in the future.
Has thanked: 1614 times
Been thanked: 4078 times
SCJ wrote: 06 Feb 2025, 16:02 The V70 arms are NOT a drop in replacement. End of story.
Or trade in your 850 for a v70 ….
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
All three of my 850s are wearing 70 series passenger side arms on the drivers side. Seem to work fine.
Robert has a video showing his bench vise bending process which also seems to help.
Clemens
Has thanked: 501 times
Been thanked: 228 times
Post by Clemens »
I bought a Volvo branded and a no name wiper arm (driver side) through Skandix and this fixed the problem on both cars, probably for a few years.
Aftermarket seems very similar, if not identic.
If you want to keep the arms from bending in the future, unload them by lifting the wipers off the windshield while parked in your garage.
1996 855 R,
2010 V70 D5,
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
I bought Pro-Parts Sweden replacements through Rockauto for both sides of my 850. They're not perfect, but they work. I do have the issue of the driver's side wiper blade doesn't flop over like it should on the up stroke. It gets chiseled into the glass. I'm not sure if that's the fault of the arm, or the wiper blade itself.
The difference between my old 99 S70 wiper system and the 850 is amazing. The 99 worked so well, and the 96 is adequate at best. Usually the washer nozzles get mentioned at this point, as a response, but it's more than that. EVERYTHING about the 99 wiper system worked better.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
DennisCA
Has thanked: 6 times
Been thanked: 71 times
Post by DennisCA »
Never been aware of this problem but yeah my wipers don't make contact at the very top. I would have liked to have seen how the dodge shadow mod worked out.
