SMöR öL: C30 Build Topic is solved
AVOIT17
Year and Model: 2009 XC90 RD
Has thanked: 6 times
Been thanked: 16 times
Post by AVOIT17 »
Wow :o
precisionguesswork
Year and Model: 2008 C30
Has thanked: 12 times
Post by precisionguesswork »
I have begun to accumulate the remaining parts needed to complete the build in the spring.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Aren't these projects usually a heavy metal guy in Finland? I guess those are usually 800 hp 740 wagons with a big pipe out the hood...
Very impressive and thorough work all around. Fun to read.
precisionguesswork
More Details, organization and Photos will be updated when progress resumes Jan-Feb-Mar.
Once completed, I will also put together a concise list of parts used throughout the the build.
I will also post links to dyno video(s) etc.
precisionguesswork
Car will be heading back into the shop next week and surgery begins...
deatschwerks fuel rail
turbosmart turbo oil feed pressure regulator
vargas turbo oil drain flange for efr7163
BMC carbon dynamic airbox
Radium 1:1 rising rate FPR w/built in dampener
Radium high flow inline fuel filter w/built in check valve and 6micron glass mat filter media
Radium catch can breathers x2
Radium flex fuel parallel bypass
radium fuel pressure gauge
Turbosmart reinforced silicone vacuum lines
oil drain fitting from block to turbo oil drain
Powerflex 95a duro drivers side motor mount insert
Powerflex 95a duro passenger side motor mount insert
Elevate coil packs
Elevate coil packs
Copper plated exhaust manifold lock nuts
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
Did you travel to 3025 AD to get those parts? Some of those are very well machined and painted.
Also -> Amazon link
precisionguesswork
matthew1 wrote: 06 Feb 2025, 17:46 Did you travel to 3025 AD to get those parts? Some of those are very well machined and painted.
All anodized billet
BlackBart
Post by BlackBart »
It's such a nice feeling to bolt together exhaust with brand new copper....ahh...
I had a muffler guy thank me for bringing new hardware so he didn't have to fight it.
precisionguesswork
I'm the muffler guy...
matthew1
Site Admin
Post by matthew1 »
everyone
precisionguesswork
Also -> Amazon link
