suggestion on stripped Torx, p80 driver airbag
Grantkat
Year and Model: 1999 s70 GLT
Has thanked: 59 times
Been thanked: 54 times
Post by Grantkat »
I am replacing the steering wheel on my 1999 S70. One of the torx bolts holding the airbag is stripped from the PO. Since I am coming into it from behind the wheel, I cant really drill. Any suggestions on a good way to get this out?
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
The head is stripped, or the threads on the bolt?
Any way to get ahold of the head from the side with a vice-grip?
Grantkat
Post by Grantkat »
the head is stripped. there is no way to get sideways. the bolt is down in a hole and requires an extended bit to reach it. the bolt body is fine...just the torx part is stripped
1999 S70 GLT ~193k
2014D VIDA/DICE
Grantkat
Post by Grantkat »
Since im replacing the steering wheel. I could cut away the plastic shell and try to cut off the bolt head then reomve the bolt body from the airbag assembly.
hoping there is a better method to avoid that
1999 S70 GLT ~193k
2014D VIDA/DICE
BlackBart
Post by BlackBart »
Arggh. I have a 90 degree drill fitting that fits in the chuck, with the bit at right angles to the drill.
Similar to this....
right angle drill.jpeg (17.24 KiB) Viewed 2382 times
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Yeah i have one of those that is probably good for one more removal.
I happen to have a wheel off, so here are a couple of pics. The screw does have a beefy head, but a shallow inset. It's recessed about 1".
You could try a bolt/screw extractor with a stubby head. Otherwise it might be grinder time.
1999 V70 GLT
Been thanked: 4065 times
You might have to go through the air bag for that, Grant
The good news is I have a couple of 99 air bags in stock free to any kat lover
Sveedy
Post by Sveedy »
I think you could cut a notch on the side of the steering wheel and gain enough access to grab the head of the screw.
1999 V70 GLT
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
An easy out type tool hammered in to the screw head MIGHT back out that screw. I would try the helical type and grind the end to a close size match before hammering.
Grantkat
Post by Grantkat »
Abscate - I sent you a DM
Sveedy - we had the same thought - the other day I removed the material from the side of the steering wheel to find that there is a cylindrical steel shaft the screw goes into so zero access from the side.
volvolugnut - i am considering that. I do have a right angle drill attachment - i may use a drill bit slightly smalled than the inside diameter of the shaft and drill the head off the bolt - then I can try to remove the threads on the bench
thanks for the ideas :)
1999 S70 GLT ~193k
2014D VIDA/DICE
