Pierburg SAS pump on closeout at Rockauto under $100
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
https://www.rockauto.com/en/moreinfo.ph ... 20&jsn=399
This is fits my 96 NA
I just got mine delivered this morning.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Kind of sad it can't just be eliminated in your State.
I have three on the shelf.
454cid
Post by 454cid »
foggydogg wrote: 08 Feb 2025, 12:09 Kind of sad it can't just be eliminated in your State.
There's no inspection here, I could convert the car to burn coal if I wanted to. I just figured it would be easier to fix the system, rather than to try to work around it. I may need to address the valve, Though. I guess the issue start with them leaking?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
Yeah, we just did the SAS delete with the diode in the ECU on her '97 GLT.
It's more of a hassle to remove all of the un-needed/dead parts than anything.
Has thanked: 1846 times
Been thanked: 1710 times
A leaking valve is usually what causes the pump to fail as you mention.
454cid
Post by 454cid »
scot850 wrote: 08 Feb 2025, 16:36 A leaking valve is usually what causes the pump to fail as you mention.
Can they be cleaned to restore function?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Nope. They fail internally. For the effort to swap and the cost of the pump, it is false economy to try to fix it. If you want to try, remove it and maybe try something like sensor cleaner sprayed into it to see if it cleans any gunk out. Once it dries out, try blowing through it both ways. If you can then it is bad. I would suggest as I said earlier, it is in my opinion a stopgap at best and as likely to cause an failure again.
454cid
Post by 454cid »
scot850 wrote: 09 Feb 2025, 05:23 Nope. They fail internally. For the effort to swap and the cost of the pump, it is false economy to try to fix it. If you want to try, remove it and maybe try something like sensor cleaner sprayed into it to see if it cleans any gunk out. Once it dries out, try blowing through it both ways. If you can then it is bad. I would suggest as I said earlier, it is in my opinion a stopgap at best and as likely to cause an failure again.
Thank you. That's what I was afraid of. I've got a new valve in my FCP cart.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
One of the issues with the SAS pump is there is no weep hole in the casing to allow condensation to leak out. After having one do what you are going through now, when I got my used replacement, I carefully drilled a 1/8" hole at the lowest point in the case to allow it to drain should the valve fail again. This did not set off any DTC's on my car doing that.
I should add, we do not have emissions testing here so I don't know it it would compromise the efficiency of the SAS system enough to fail an inspection.
454cid
Post by 454cid »
I'm still waiting for the valve from FCP. I got the gasket yesterday... they shipped a tiny gasket in a box that's approximately the size of a shoe box! I got free shipping, but am still horrified by the waste.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
