When using this support, I try to position it just above the lifting rings on the engine. That way the engine is not pulling the bar front or rearwards. Did this recently on 2 cars, an XC60 and a P80 V70. No issues, and both were up on a hoist.
- Has thanked: 1841 times
- Been thanked: 1710 times
- Has thanked: 1502 times
- Been thanked: 3813 times
I used that for clutch replacement on my P2. Just get the feet in the rail and it won’t tip.
- Krons
- Has thanked: 193 times
- Been thanked: 202 times
When I did subframe bushings I did have to get the subframe high enough to line the new cap screws up. I was doing one at a time though and not complete subframe removal. For complete reinstall I’d start all four finger tight before torquing them down per the torque turn procedure on the new cap screws.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
New screws, very high torque
LongNoseElk
- Year and Model: 2006 V70
- Has thanked: 123 times
- Been thanked: 24 times
The elk had an issue with not opening the fuel filler door release. Of course it had to happen at a gas station, as the gas tank was as good as dry...
Tried to find the emergency release handle behind the trunk interior side cover without success.
Flipped a coin in my mind and took the trip to the mechanic/ dealer, some 50 kilometers away. Missed an exit on the way (D'Oh!) to drive some neverending extra 4 kilometers.
Arrived at the mechanic with the board computer showing "- - km range"!
The mechanic took 5 seconds to disable the fuel filler door release engine.
While I was there, I mentioned the broken front left position light and parking light and that I planned to repair them on a sunny weekend.
Boy I'm glad that the dealer insisted to repair it right there...the air filter and some hoses have to be loosened to reach the left front lamp housing.
Did I mention they did all this for free and even served me a coffee?
Good man.
Good man.
2006 Volvo V70 black
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 126 times
- Been thanked: 116 times
Got a definite vacuum leak on the 2.4 NA. Any common places to look? I see one what seems to be 3/8 hose off the intake manifold that looks crumby.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
I think the P2s have that same hose under the intake manifold to the purge line that gets crumbly, check that.
Also the brake vacuum switch can leak and cause issues too.
dikidera
- Year and Model: S60 2005
- Has thanked: 67 times
- Been thanked: 175 times
I believe I've also identified one, it's not from brake hose, or any vacuum hose. What is left is either intake manifold gasket, PTC heater or something like the PCV itself.
dikidera
I measured the width between the fenders to be around 160cm, somehow there's no support bar at least that long in my country for a reasonable price. All of them are like 148cm at best, too short.
