I think it's a vacuum leak coming from somewhere. Seems to happen under load. Any thoughts? I pulled the console but you can only see so many vacuum tubes.
1993 240 trumpet sound in dash
- Has thanked: 987 times
- Been thanked: 1075 times
When you hear the sound, what things are on? heater fan? Radio? changing vent positions?
If the dash is still out, disconnect the speedometer cable (if it has one).
Disconnect all dash wires and try a drive.
RockVegas
- Year and Model: 1995 850 Turbo Wagon
Good question. Seemingly nothing changes it, defrost, vents, radio, nothing. Happens consistently (more or less when I'm up to cruising speed then i have to give it a little more gas to climb a few miles per hour. Once I'm there, let off a bit on gas, goes away for the most part. I'll try some of your suggestions. Thanks!
- 1618 Views
Last post by nancynywoman
- 10 Replies
- 5656 Views
Last post by JimBee
- 1547 Views
Last post by azureblue
- 10 Replies
- 2820 Views
Last post by mdewalle
- 1000 Views
Last post by Assi1979
