Glovebox kickpanel fix repair - DIY ABS plastic parts (not brakes) - S70/V70
This topic is in the MVS Volvo Repair Database » Kick Panel Broken Tabs Fix
Grantkat
Year and Model: 1999 s70 GLT
Has thanked: 47 times
Been thanked: 43 times
Re: Look at this for ABS plastic parts ( not brakes) repair
Post by Grantkat »
Yes you can still get MEK here, either online or through some suppliers. Volvolugnut is correct -you dont want to be working around this stuff alot and you want a ventilated space to do it.
You can also use ACETONE which is more readily available. The fix above worked like a charm. However I want to correct a few things and I have some more insight.
Most of the parts, at least the ones I have scrounged are stamped PC + ABS - Volvo makes these parts as a combination of Polycarbonate and ABS plastics. Polycarbonate resists organic solvents like MEK and Acetone. so home made slurry is not possible in those cases. I tried it the other day and it did not work.
I Ordered some ABS filament (used as 3D printer material) which is pure abs and I am going to try and document a fix from beginning to end including the slurry. For me, its just a challenge and some fun trying to fix it. Clearly you can replace broken or crack parts with new or salvaged ones if its not your cup of tea.
I generally agree with all above. These fixes are not going to work in certain situations like parts under alot of stress.
my test project is a pillar molding which has a crack in it. I will keep you posted.
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2650 times
Been thanked: 1240 times
Post by matthew1 »
@Grantkat I put this in the Volvo Repair Database and made your account MVS Contributor level. Thank you!
Standard plea: If anyone here knows of a repair that should be in the VRD, please contact me and let me know and I'll do it.
Also -> Amazon link
Has thanked: 1497 times
Been thanked: 3809 times
Thanks for doing this. I think the era of finding good plastic parts in junkyards for P80s drawing to a close like 8 track cassettes.
Has thanked: 1834 times
Been thanked: 1709 times
Oh no! Surely not. :cry:
