Essential tools for DIY Volvo care.
pfmet
- Year and Model: V70 1999
- Has thanked: 44 times
- Been thanked: 22 times
Re: Essential tools for DIY Volvo care.
Jonesg, ….I need to know, where does one buy a quality flare wrench set for $13? I just spent $23 for a 13mm SK flare wrench to do front brakes on my truck. My old Craftsmen showed signs of spreading and rounding a nut on the Volvo a couple years ago. Spend some real money on your flare wrenches. When it comes to flare/line wrenches I buy them individually as I need them and spend some real money on a better than decent one. SK’s have proven good.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 479 times
$12.pfmet wrote: ↑01 Mar 2025, 19:26 Jonesg, ….I need to know, where does one buy a quality flare wrench set for $13? I just spent $23 for a 13mm SK flare wrench to do front brakes on my truck. My old Craftsmen showed signs of spreading and rounding a nut on the Volvo a couple years ago. Spend some real money on your flare wrenches. When it comes to flare/line wrenches I buy them individually as I need them and spend some real money on a better than decent one. SK’s have proven good.
https://www.amazon.com/SATA-Full-Polish ... t_ba_s_1_t
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 603 times
MAPP torch the bleeder screws and replace them. I replace them every time I bleed the brakes.pfmet wrote: ↑01 Mar 2025, 19:26 Jonesg, ….I need to know, where does one buy a quality flare wrench set for $13? I just spent $23 for a 13mm SK flare wrench to do front brakes on my truck. My old Craftsmen showed signs of spreading and rounding a nut on the Volvo a couple years ago. Spend some real money on your flare wrenches. When it comes to flare/line wrenches I buy them individually as I need them and spend some real money on a better than decent one. SK’s have proven good.
- Has thanked: 1497 times
- Been thanked: 3810 times
Tekton has a nice line of tools that are Snap-on quality without the Strap-on price.
Replacing bleeders on the 2-3 year brake fluid interval will keep them from snapping off and save you Eons of time.
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
Can you push out all the old brake fluid by flushing it through? There’s no low point where you can just drain it, and you’ve got ABS piping.
pfmet
SATA and Tekton aren’t included here but it’s a good overview of the landscape of tool quality. From what I’ve read (Garage Journal and Reddit tool forums I don’t think I’d use SATA’s on my brake lines.
TlDW
Snap on , SK , Matco seem to top out the quality list
Too long didn’t watch
I did watch it , it was good. Trying to give a summary for those short on time
- jonesg
on the front end, if I'm swapping out flex hoses I hit it with the torch if it doesn't want to play easy.
or chop it off and just use a socket.
or , less radical, put it under pressure and tap the union with a hammer.
Double wrenching or cheater pipes is a failure to understand how to use the wrench.
