'98 S-70 turbo 1992-1998 coil resistance specifications
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I looked into this for the 850 series in 2020... don't know if the 1998 70 series is the same:
viewtopic.php?t=93975
According the the Haynes manual for the 850 (may be different than the 1998 S70), the coil primary should read between 0.5 to 1.5 Ohms and the secondary should read between 8000 and 9000 Ohms for 1994 and on. I checked my spare coil (from a '96) and got values in that range. For pre-1994 B5252S engines, the primary resistance is "not specified" and the secondary should be between 6000 and 7000 Ohms.
Primary refers to the resistance between the two lug terminals.
Secondary refers to the resistance between the Coil tower (plug leading to the Distributor and case ground.
You should consider resistance measurements as necessary but not sufficient, data to confirm a good part, ie values in spec mean the coil is potentially, but not confirmed, in working condition.
Values out of spec are 99% sufficient to confirm a bad part.
- Has thanked: 311 times
- Been thanked: 817 times
Great info from jreed.jreed wrote: 03 Mar 2025, 05:18 I looked into this for the 850 series in 2020... don't know if the 1998 70 series is the same:
Yes, 98 S70 coil is exactly the same as a 95+ 850.
Added to title and need to add coil part number, if anyone knows it please add to thread by reply
- jreed
According to the FCP website one of the Volvo part numbers is 1275174.
The Bosch part number is 0221601012
- 13 Replies
- 8853 Views
- 1564 Views
Last post by ryanwawro0920
- 1984 Views
- 3083 Views
Last post by Redneck
- 565 Views
Last post by E Showell
