Essential tools for DIY Volvo care.
pfmet
Year and Model: V70 1999
Has thanked: 44 times
Been thanked: 22 times
Re: Essential tools for DIY Volvo care.
Post by pfmet »
Jonesg, ….I need to know, where does one buy a quality flare wrench set for $13? I just spent $23 for a 13mm SK flare wrench to do front brakes on my truck. My old Craftsmen showed signs of spreading and rounding a nut on the Volvo a couple years ago. Spend some real money on your flare wrenches. When it comes to flare/line wrenches I buy them individually as I need them and spend some real money on a better than decent one. SK’s have proven good.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
pfmet wrote: 01 Mar 2025, 19:26 Jonesg, ….I need to know, where does one buy a quality flare wrench set for $13? I just spent $23 for a 13mm SK flare wrench to do front brakes on my truck. My old Craftsmen showed signs of spreading and rounding a nut on the Volvo a couple years ago. Spend some real money on your flare wrenches. When it comes to flare/line wrenches I buy them individually as I need them and spend some real money on a better than decent one. SK’s have proven good.
$12.
https://www.amazon.com/SATA-Full-Polish ... t_ba_s_1_t
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 604 times
Post by vtl »
MAPP torch the bleeder screws and replace them. I replace them every time I bleed the brakes.
Has thanked: 1498 times
Been thanked: 3810 times
Tekton has a nice line of tools that are Snap-on quality without the Strap-on price.
Replacing bleeders on the 2-3 year brake fluid interval will keep them from snapping off and save you Eons of time.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Can you push out all the old brake fluid by flushing it through? There’s no low point where you can just drain it, and you’ve got ABS piping.
pfmet
Post by pfmet »
SATA and Tekton aren’t included here but it’s a good overview of the landscape of tool quality. From what I’ve read (Garage Journal and Reddit tool forums I don’t think I’d use SATA’s on my brake lines.
TlDW
Snap on , SK , Matco seem to top out the quality list
pfmet
Post by pfmet »
Transverse Interdural Width..? Not strictly an an anatomical term?? Why not.
pfmet wrote: 03 Mar 2025, 06:24 Transverse Interdural Width..? Not strictly an an anatomical term?? Why not.
Too long didn’t watch
I did watch it , it was good. Trying to give a summary for those short on time
jonesg
Post by jonesg »
on the front end, if I'm swapping out flex hoses I hit it with the torch if it doesn't want to play easy.
or chop it off and just use a socket.
or , less radical, put it under pressure and tap the union with a hammer.
Double wrenching or cheater pipes is a failure to understand how to use the wrench.
