Want to know what your particular VIN Number means?
It is quick, painless and what I needed!
http://www.volvoclub.org.uk/vin_70.shtml
Volvo Vin Deciphering site
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Great Info...I'm pinning this in the repair database!
MIJ
Just a note...I checked our cars against the VIN Decoder and since this is a UK site, the transmission doesn't show up...for instance, the '04 V70 shows "0" for the tranny but that's not included...just says "check digits" for U.S. models. Other than that, it's spot on! Country code "2" is Gothemburg, Sweden but don't know about the others.
MIJ
osolanog850
- Year and Model: 1994
Hi
one question, my VIN engine number is 55, the number on the block said B5254S, and the document shows two different engine numbers: B5254FS & B5254S DENSO, so what does it mean? FS & DENSO?
Thanks
Thanks
'94 850 Manual 39,300 Km
'94 850 Autom 45,000 Miles
Correct me if I'm wrong ....it's the difference between a DENSO and Bosch
ECU setup/system.
ECU setup/system.
Doug <///><
1999 Volvo V70 LT AWD X/C 143k back from the dead.
1995 Jeep Rangler Rio Grande 243k
1994 BMW 325i Sedan 226k
MadeInJapan
Yes, it is the difference between ECU's....DENSO or MOTRONIC (Bosch)...the VIN won't tell you this, apparently. The only way to tell is to open your ECU box and check it (for that particular year). We know however that V70's from '98 and earlier are all Bosch while '99 and newer might have had DENSO as do some S80's an other models.
- 13 Replies
- 4146 Views
- 1195 Views
Last post by Sspire0124
- 3501 Views
Last post by jimmy57
- 3881 Views
Last post by scaro
- 751 Views
Last post by Kamekaze
