Essential tools for DIY Volvo care.
Has thanked: 1611 times
Been thanked: 4072 times
It’s amazing how much less stuff I break using 30 seconds of propane heat on most any bolt underneath.
Even this came apart….
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
abscate wrote: 05 Mar 2025, 02:53 It’s amazing how much less stuff I break using 30 seconds of propane heat on most any bolt underneath.
You mean you put the whole car on fire and the rust problem is finally solved? =)
vtl
Post by vtl »
BlackBart wrote: 02 Mar 2025, 12:53 Can you push out all the old brake fluid by flushing it through? There’s no low point where you can just drain it, and you’ve got ABS piping.
Remove the caliper, open the bleeder, push piston(s) in. Start bleeding line normally (with a bleeder). The remaining old fluid will be a tiny drop in passage between bleeder screw and piston.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Did this self disassemble on the road?
volvolugnutr
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
The blue wrench, I upgraded to the yellow wrench.
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
abscate wrote: 05 Mar 2025, 02:53 Even this came apart….
Oh
My
Gawd....
BlackBart
Post by BlackBart »
volvolugnut wrote: 05 Mar 2025, 09:42 Even this came apart….
volvolugnutr
[/quote]
Unscheduled Rapid Disassembly?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Is there any "this" there?
Also -> Amazon link
