SMöR öL: C30 Build Topic is solved
precisionguesswork
Year and Model: 2008 C30
Has thanked: 12 times
Been thanked: 16 times
Post by precisionguesswork »
Upgraded from ID1050xds to ID1300xds injectors and from the DW300c to the DW400 pump.
Everything should be back from Cerakote next week. I expect to make leaps in progress, if not nearly finish up
after the parts are in hand. Heat shielding for the fuel lines, turbo coolant lines, and turbo oil feed line will be ordered tomorrow as will the upgraded pump. ID1300s are in hand. Will be able to wrap up the Setrab oil cooler and Improved Racing inline thermostat. Couple of odds and ends fittings, bolts, hose clamps and cleaning.
precisionguesswork
Need to weld a cast 90 onto the compressor outlet to clear the power steering lines. This bit will make more sense once I upload images
precisionguesswork
Picking up parts from Cerakote today..
pics to follow
precisionguesswork
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Some of those pieces look like they were manufactured on the International Space Station. Just beautiful. Good thing they'll live inside a 3000-pound metal case to protect them.
Also -> Amazon link
precisionguesswork
Back in the shop tomorrow
precisionguesswork
Fuel lines, rail, injectors, regulator, fuel pressure gauge,
eFlexFuel injector harness, flex fuel sensor, Radium parallel bypass, intake plenum, throttle body, sway bar, oil cooler blocking plate are all in. Back in shop today, more to follow.
precisionguesswork
Exhaust manifold is in permanently. Mocked up turbo for vac lines and next project will be, cold side, charge pipe, welding neck onto compressor outlet, and with any luck oil cooler.
precisionguesswork
sorting out the oil drain, had to grab an ultra low profile oil drain flange as the turbo is now about 2" lower than K16/Stock. Set up fittings on the turbo, less the coolant lines to again verify I'm good on space constraints. All clear.
precisionguesswork
Ran out of time due to remodeling my daughter's home to be ready for sale this spring. Car is back in storage until around thanksgiving.
To be continued....
