Like an idiot, I tried to use a screwdriver to pry the accessory belt onto the power steering pulley. I cracked off the lip, which I assume will shred the belt over time.
New PS pumps start at $200 - has anyone had luck just replacing the pulley? I realize this is a bizarre edge case and I should just go to the junkyard...
Also, the suggested procedure for this belt install is to relax the tensioner with a t60 star bit in the tensioner housing, but a 1/2" T60 socket + 1/2 rachet is too wide for the gap between the 2.5 engine and the firewall. There must be a trick?
Cracked off the the lip of the power steering pulley. Replacement pulley?
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
That’s the method I use for the tensioner, it’s a little dirty but it does work. The serpentine belt should last for awhile with that pulley while you source a replacement, I’d just grab one from the auto wreckers.
2003 XC 70 (sold)
- Been thanked: 504 times
- I use the Serp Belt Tool (Harbor Freight or online ebay etc.), it has a flat profile and fits in that tight space.
- Not sure if it is safe to run it that way. If the Serp belt ever comes loose, it may get sucked into the timing belt comparment --->
Good Bye engine.
- Idk if the pulley itself can be replaced? Has anyone tried? I am curious.
- Or get a used PS Pump from junk yard from a low-mileage car.
NOTE: diameters of the pulley are different up-to-2004 vs 2005-2009 years. Verify before buying.
Good Bye engine.
- Been thanked: 4064 times
This.
Some nice work with file and then even a bit of JB weld if you feel industrious.
The ABN tool from the jungle makes serp belt replacement easy as pie, or 3.1415926535……
- 1242 Views
Last post by Azik09
- 1656 Views
Last post by SuperHerman
- 4093 Views
Last post by otis44
- 1340 Views
Last post by SSR
- 3951 Views
Last post by Juan62
