P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
That's not rust, it's patina... :roll: :D
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Has thanked: 2203 times
Been thanked: 1852 times
:o :lol: :lol:
P80GLT
Post by P80GLT »
I gave Kära a wash today, yes I know some of you guys prefer dirty girls but we're a little more civilised here in Scotland :lol:
She's now basking in the sunshine with all the doors open.
I also took the liberty of swaping out the rubber winter floor mats onto my summer specials. Bring on the shoeless driving with the thick pile carpets in place... 😁😁😁
2010 XC90 SE...SOLD
2005 V70 2.5T SE
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Krons wrote: 13 Mar 2025, 15:20 I was able to get the 120° with a 25” breaker bar. Eat a big breakfast.
You, the sub-200 lbs dudes, can't even torque the subframe bolts properly!
vtl
Post by vtl »
dikidera wrote: 14 Mar 2025, 07:33 It is alive. I drove it for a while. I def need an alignment due to the rebuilt rack.
The new tranny shifts much better, except 3-4th, but 2-3 is waaaay better. HOWEVER! i am noticing a turbo-like noise before it shifts. I drive a NA engine! No turbo! I can't figure what it is. It can't be the transmission oil pump, can it?.
Addendum: Yep, I mean I had this on my previous transmission but it was only ever perceptable from 1st to 2nd when going very slow like less than 10mph., now this one I can hear it even more clearly from 1st to 2nd and 2nd to 3rd. Very slightly noticeable in Neutral and does not seem to be noticeable at higher gears.
The whine is stronger in reverse.
Perhaps vtl has some idea?
Could be slack in differential. Thrust bearing can pick its race and it grinds through transmission casing. The preload in both bearings is gone then, they can whine. Differential gears can whine, too.
vtl was testing an idea if sauna tent pitched on top of 6 feet of snow in 50+ degree (F) weather is any good. Ended up steaming in snow shoes...
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
I installed a Curt hitch on Greta a few days ago in preparation for a little road trip, where I will be towing a small Uhaul box trailer. Fitment was lousy. On the passenger side the slots in the mounting bracket did not line up with the nuts in the frame rail, and I had to elongate them with a hand file by about 1/16". The hitch cannot be moved side to side, because the brackets fit snug next to the trunk floor walls. Once that was done the installation is super easy.
Next is installing the transmission cooler and the trailer light module with wiring.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
vtl wrote: 20 Mar 2025, 10:57
Which is the lesser evil? :D
Anyway, for the past month I've had my lower hose pop off. Obviously the loss of coolant started to become dreaded, I can't keep traveling with new antifreeze every time not knowing when it will pop off.
Turns out my replacement radiator I installed a while back has a nipple that lacks a support ring(sleeve?) inside, the nipple has collapsed, deformed maybe even cracked from the hose clamp pressure. The replacement radiator is NRF if I remember and even then I noticed the lack of a support ring inside the nipple before I even installed it. I removed the support ring from the old broken radiator and will try to install it in this one provided that the inside diameter is at least big enough to allow me to fit it inside. Sadly I have no glue with which to fix it in place.
Of course fitting is one thing, it's whether the radiator nipple is damaged beyond this repair can fix.
Been thanked: 4068 times
850 LPT wrote: 20 Mar 2025, 12:19 I installed a Curt hitch on Greta a few days ago in preparation for a little road trip, where I will be towing a small Uhaul box trailer. Fitment was lousy. On the passenger side the slots in the mounting bracket did not line up with the nuts in the frame rail, and I had to elongate them with a hand file by about 1/16". The hitch cannot be moved side to side, because the brackets fit snug next to the trunk floor walls. Once that was done the installation is super easy.
That was the Curt hitch, right Dirk?
Can you list the wiring package you bought please? Need to do Catherine the V70 p2 2005
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
abscate wrote: 21 Mar 2025, 04:27
viewtopic.php?p=596390#p596390
04s60 2.4
04xc70 2.5t
850 LPT
Post by 850 LPT »
Correct, it's the Curt hitch. This is the wiring harness with module that I ordered, it's the only generic 4 pole listed on their site for P2 Volvo:
https://www.etrailer.com/Custom-Fit-Veh ... 59236.html
Should be straightforward to install, but I will report back when I actually get to it.
