Glove Box "Absorber" - 2004 V70 2.5T Topic is solved
rntaboy
Has thanked: 6 times
Been thanked: 8 times
Post by rntaboy »
Recently my glove box door stopped openly fully. I wasn't able to get a good look at what was happening because of the lack of opening, but after some quick research on the typical cause and replacement procedure I ordered a Glove Box Support (9491713) off FCPEuro. The shock arrives and I go to do the replacement, and magically the glovebox opens normally for the first time in weeks. But the mechanism to slow open the glove box is significantly different than all the videos/guides/VIDA replacement instructions I've seen.
The mechanism on my V70 looks like this:
Screenshot 2025-03-31 083422.png (466.25 KiB) Viewed 544 times
Screenshot 2025-03-31 084320.png (134.21 KiB) Viewed 544 times
I haven't checked with any of the online Volvo parts suppliers directly yet to confirm, but it does not seem like that "absorber" (30643810) is available in new stock anywhere.
Does anyone have any knowledge about this glove box bit, where to best source a replacement (preferably new), or any info on how it can be repaired?
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
I can't imagine it is possible to wear it. It is just a loaded spring, basically. What happened to yours?
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
The chord is liable to breaking. It can be re-stringed but getting the correct tension takes a few attempts to get it just right
The plunger isn't the easiest of items to dismantle, the bottom part of the plunger is tricky to separate and requires gentle persuasion.
It took me several attempts with the length of the cord before I found something close to what it should be. I settled for 195mm between the knot and top of the loop
All back together and ready to refit. Note I fitted the grommet incorrectly in this picture it should be facing the opposite direction
Grommit is inserted from behind
Now works as it should
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Been thanked: 504 times
Post by cn90 »
Try local junk yard for this part that is NLA.
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 67 times
Been thanked: 93 times
Post by DavidE7 »
It is possible to install the plastic tube body in the wrong orientation - upside down. I made this mistake when replacing a broken part. When it is upside down the spring and plunger tend to bind. I don't have a picture handy for the correct install position.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
Been thanked: 4065 times
If someone writes up removal instructions I can harvest ftom my 2004 carcass next trip up North.
rntaboy
Post by rntaboy »
I appreciate all the replies, and the excellent instructions from P80GLT.
Not sure what goofed up on mine, but it is currently working properly for some reason after weeks of being stuck. I'll add it to my list of bits to look out for next time I hit up the junkyard to scavenge replacement/backup parts.
