Alternator minimum brush length ?
Mike98
Year and Model: V70 2006 NA
Been thanked: 4 times
Post by Mike98 »
My 2006 V70 NA has 116,000 miles. The intake manifold is off because I am replacing the PCV breather box and hoses. This is a good opportunity to check the alternator because it would be easy to remove/replace if necessary. The alternator pulley and bearings seem fine. I removed the alternator back cover and voltage regulator to check the brushes.
One brush extends 7.5 mm beyond the holder and the other brush extends about 9.5mm. See the 2 pictures below.
What is the minimum brush length for reliable operation ? Any guess at the remaining mileage for my brushes ?
Thanks,
Mike
2006 V70 NA M56 116K
2006 V70 M56 NA
Vova585
Has thanked: 228 times
Been thanked: 238 times
Post by Vova585 »
They look like they should last at least another 10k or so. However for $32 I would put a new unit and forget about it for another 15 years.
I am not 100% sure but some alternators were coming with free spinning pooley. If you are there it is worth checking serpentine belt and if your pulley is still free rolling.
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
I replaced mine with about that much life left
https://www.freel2.com/forum/topic39641.html
I agree with the recommendation to replace.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
My manual says 5 mm is minimum length.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
I have a new regulator in the garage, its dark now but I'll measure the brushes Sunday.
jonesg
Post by jonesg »
the new bosch one I have is just over 1/2 inch.
Yours are longer than my new one.
this one is 5/8ths.
